1995 corvette wheels flaking
Old Dec 26, 2022 | 07:19 PM
1995corvetteowner's Avatar
1995corvetteowner
8th Gear
Default 1995 corvette wheels flaking
Hello
I have just purchased a 1995 corvette. I noticed the rims are flaking/peeling and had some kind of clear coat, any suggestions on how to fix or remove.
Steve
Flaking or peeling
Old Dec 27, 2022 | 09:51 AM
QCVette's Avatar
QCVette
Active Streak: 90 Days
The only way I know of is to strip the clear coat off the wheels.
This can be done with chemical strippers. It will take the clear coat much quicker than the silver paint which I think may be a powder coat and much tougher.
Once the clear is off, then you have a choice to reclear or not.
If you do not, the wheels may need a quick detail or hand polish occasionally. Without the clear, the wheels will look a little brighter too.
If you do reclear them make sure the material used is top quality. I used a rattle can and it looked good for about 2 years and then started to yellow, so I don't recommend that. A paint shop may have better paints and be able to spray it well, but it will cost more.
Good luck.
Old Dec 27, 2022 | 11:35 AM
Talfryyn's Avatar
Talfryyn
You can strip them and have them powder coated in clear. They make clear powders specifically for wheels.
if you coat them yourself SprayMax 2k clear glamor is a good product.
Old Dec 28, 2022 | 12:16 PM
1995corvetteowner
8th Gear
Default Rims peeling
Thank you , appreciate the advice
To 1995 corvette wheels flaking
