I am visiting my folks in Texas for Christmas, and I swear my 1989 is making a fair bit more power than it does up at 5000ft in Albuquerque NM.
My car made 225 rwhp on a dyno in Albuquerque before I straight piped it with long tube headers, so I am estimating it is currently making around 250 rwhp at elevation.
I read that each 1000 feet of elevation corresponds to around 3% power lost/gained, so perhaps I am now somewhere around 270rwhp here at sea level?
the car is pulling harder, and I can break traction in ways that I could not up in Albuquerque
What do yall think
Completely normal. If it was a carb, you would re jet it for every 1k feet in elevation. Same reason water boils quicker due to elevation.. all about the pressure.
We had some -2500 to -3000 DA conditions here in DFW over the past week. There is no doubt that you are making more power in these conditions vs being at 5000 ft in NM.
Current DA conditions in ABQ = 5105.10 ft
Current DA conditions in DFW = -1396.45 ft
It's easier to think of if you consider this: A one square in column of air (atmosphere air pressure) normally weights 14.7 pounds at sea level. When you are 5000 feet above sea level, that column of air weighs about half as much. It's the added air pressure that gives you the little boost of power you are feeling, almost like a NOx system does.. If you can tune your engine to react to this, you'll find some favorable results!
What do yall think
I think that a physicist should already know this, cold. It's a known thing: 3% loss per 1000' elevation. Also well know is that virtually any RWHP dyno is going to produce a "corrected" number, and atmosphere is part of that correction, so while you got a number that says 225 in Albuquerque, your car was actually making about 191 RWHP on that particular pull.
Your car IS pulling harder down in Texass, because now, it's making much closer to the 225 RWHP that your pull reported, when corrected up in NM. Which in comparison, probably feels pretty awesome!
Right on, so sounds like I ought indeed perceive somewhere around 10-20% more power?
I honestly don't appreciate that. I know a lot of professional physicists with dissertations and publications in various subfields, myself included, that through no fault of their own are ignorant of many things automotive related or outside their area of expertise.
Well? You threw it out there like the slam-dunk trump card. I guess I didn't appreciate it. I'd think any physicist could figure this out very easily.
If course, when you take away percentages, the % value is smaller than when you add it back, since the same number is coming from a larger value. Starting with a 245hp engine that lives at 5000' elevation: 3% * 5k' = 15% (loss). 245hp*.85= 208net chp, in NM.
Going back, (or going DOWN to Texass) it's going to take 17% to get back since your adding the same number to a smaller value; 208hp * 1.17 = 243.36 Net chp.
You should perceive ~17% more power and tq. which is awesome and fun! I live at 7k feet and when I take my cars to low elevation....HOT diggity DOG!!
