Driver side window not working
Old Jan 24, 2023 | 01:54 PM
Bmblushi's Avatar
Bmblushi
3rd Gear
Default Driver side window not working
I know, you’ll say “check the other posts”, but i did, and nothing there has helped. The driver side window on my 91 corvette recently stopped rolling down after heavy rain. I hear a very quiet noise coming from the door panel and have been able to very slightly move the window down, but now cannot move it from that spot. I’ve tried slamming the door while holding the switch as well as wrapping on the inside of the door and got nothing. Is there anything else i can do short of a new motor?
Also sorry if this is in the wrong section
Old Jan 24, 2023 | 03:49 PM
Topduarte's Avatar
Topduarte
I bet water got in the motor. Maybe motor burned out.
Old Jan 24, 2023 | 03:56 PM
Polo Vert's Avatar
Polo Vert
My window would work intermittently on my 94. Can't get a new driver side window switch so I took the original apart, very carefully because they aren't really designed to come apart and cleaned it, put it back together and it worked fine. Carbon build up on the contacts. Might not be your issue but it is something you can try for free.
Old Jan 24, 2023 | 04:41 PM
Bmblushi's Avatar
Bmblushi
3rd Gear
seems like a possibility, i can hear the motor try to move but it’s very weak. would rather not replace bc taking apart the door is abt as fun as pulling teeth
To Driver side window not working
