Need help
Bought a new 180 degree thermostat, new hoses, fan relays, temp sensors, knock sensors and coolant. Spent a good part of a day replacing it all and doing a coolant flush, all was going well until I took the car off the jack stands and filled it with coolant. Before doing the coolant flush it would get up to 220 degrees just fine and would get down to around 200 while I was moving. Once doing the coolant flush though I can start it up and it will run just fine until it hit 180 degrees and it would die. I would immediately try and start it again and it would just crank with no start and eventually back fire through the intake. Let the engine cool off and turn the key and it fires right up and runs great until that 180 degrees and it dies again. It threw a dct 43 code which following the service manual it led me to a faulty ICM, replaced the ICM and it runs better than I've ever heard it run, had hopes this would fix the issue I was having but nope. It got to 192 degrees and die, immediately turned the key again and it actually fired back up this time and it proceeded to get 220 degrees. Once it reached that 220 mark the rpm began to struggle, it's idle fluctuated and wanted to die and once at 223 degrees if you touch the gas pedal it immediately bogs and starts misfiring. Any solution to this would be greatly appreciated
Did you by chance let any coolant run down toward the OptiSpark? It's below the water pump and if water gets in it, it really screws it up. I think the symptoms you're experiencing are similar to those that others with bad Opti's have reported.
Again, I'm just going by what I've read, so take this for what's worth - which may not be much!
Are you aware that the Gen-2 LT1 uses a different thermostat that the older 350 designs (because of the reverse flow design)
Also the temp sensor at the front of the engine by the thermostat housing is the sensor that sends it's signal to the engines control module used to determine when the engine is in closed loop. Sometimes this important sensor gets damaged when replacing things.
Each year functions slightly differently .... but on my 95 both fans come on at low speed when the "digital" temp display (this is that signal from the temp sensor at the front of the engine) reaches approx 228F (they turn off after an approx 5 degree drop in tenp). the fans do not come on at high speed until the digital temp reaches approx 237F and after a 5 degree drop they switch to low speed.
