Hurst Shifter
Old Feb 22, 2023 | 02:30 PM
Johndobropicker's Avatar
Johndobropicker
3rd Gear
Default Hurst Shifter
I have a 1985 Corvette 4+3,and was wondering if anyone has replaced the factory Shifter with a Hurst Shifter,and what problems you ran into,If any ?
Old Feb 22, 2023 | 05:13 PM
85 Z51's Avatar
85 Z51
I do not think that anyone makes an aftermarket shifter for us 4+3 guys... I have heard that you can modify your existing arms to make shorter shifts, but I have not tried that.
Old Feb 22, 2023 | 10:24 PM
LiveWire1's Avatar
LiveWire1
About the only thing you could do is to drill new holes in the shift levers at the transmission. It would probably pay to drill them large and put in some bronze bushings, because when the fulcrum gets shorter, the leverage increases. Shorter shifts require more force at the shifter.
Old Feb 23, 2023 | 03:04 AM
topfuel67's Avatar
topfuel67
I have a 92 6 speed and it has the B&M short shifter. It's really annoying. I thought my transmission was on its last legs as it takes a lot of effort to shift into all the gears, but it doesn't grind at all. I read on here that it is a common issue with the short shifters. They reduce the leverage ratio in your shifting. So keep that in mind if you decide to change it. The Corvette shifter isn't like older cars where you have a longer shifter.
Old Feb 23, 2023 | 09:47 AM
jazfe's Avatar
jazfe
The C4 shifter is attached to the transmission tunnel not to the transmission itself so no one makes an aftermarket shifter for these cars. I found a short shift kit about 5 years back which only consists of different links at the transmission. As stated previously they only move the fulcrum which makes for heavier shifts.
I am sending my "shift kit" to SurfnSun so he can copy them for folks that want a set. I am updating to a ZF6.
Old Feb 23, 2023 | 10:34 AM
QCVette's Avatar
QCVette
Active Streak: 90 Days
Instead of modification to the shift arms, you could try the ones from Ecklers for about $20.
https://www.ecklerscorvette.com/1984...-111063-1.html
Like others said, it will probably make the shift effort a little higher.
Good luck.
Old Feb 25, 2023 | 12:37 AM
iceman2003's Avatar
iceman2003
Hello, Please let us know how it works out manufacturing your own than you, Cheers.
Old Feb 25, 2023 | 08:34 AM
dizwiz24's Avatar
dizwiz24
i use my hurst shifter to help me out-shift (shift faster) than cars with the new stupid-tech dual synchronized whatever style transmissions
give me a clutch pedal and a short throw shifter vs. some millenial that doesnt know how to drive their automatic mustang and ill shift faster everytime
Old Feb 25, 2023 | 10:32 AM
Mixednuttz's Avatar
Mixednuttz
2023 Corvette of the Year Finalist - Modified
2022 C4 of the Year Winner - Modified
Finalist 2020 C4 of the Year - Modified
Old Feb 26, 2023 | 08:32 AM
dizwiz24's Avatar
dizwiz24
Originally Posted by mixednuttz
Old Feb 26, 2023 | 02:46 PM
Hhdouy's Avatar
Hhdouy
Banned Scam/Spammer
Old Mar 29, 2023 | 04:51 PM
InfomanSS's Avatar
InfomanSS
What if one started with this installation kit: https://www.summitracing.com/parts/huu-3738616
Scrolling down and looking at the application data, it does specifically list the C4.
And then added this shifter: https://www.summitracing.com/parts/huu-3917535
This path could create some problems:
1. Cosmetic (mine is mainly a track car...I don't even have a center console...not too worried about that), and
2. Overdrive Switch
a. Mount existing switch to side of shifter stick or the dash to be out of the way on the track, or
b. Rig up something with a shifter **** momentary switch (the interesting part is that the circuit needs to be closed by default and the momentary switch temporarily opens the circuit)
https://www.summitracing.com/search/...rder=Ascending
That is one pricey shifter package.
To Hurst Shifter
