Hard Start
Old Feb 23, 2023 | 10:13 PM
SBell's Avatar
SBell
Default Hard Start
I need some help with my LT-4. The car starts good when cold, but there are times after it has run for awhile that it gets hard to start, and after 2 or 3 tries it will being to run. I have replaced the fuel injectors, fuel pump & sending unit, Coil, Opti, spark plugs & wires, and even the IAC. Anyone out there had this problem, have any ideas of what to do, or where to look next?
Old Feb 24, 2023 | 03:41 PM
Blue Bucket List's Avatar
Blue Bucket List
A couple quick questions, do you have the factory service manual specific to your year model and do you have a SES light on the dash? The FSM is invaluable to help you fix whatever is going on. Along with the many many knowledgeable people on here. Being that you state you have an LT4 you have an OBD2 system that most any code reader can give you some idea what's going on.
Old Feb 24, 2023 | 04:28 PM
SBell's Avatar
SBell
I have 94 OBD1 so no codes. I pulled the engine from a wrecked 96. I do have a service manual on cd, but haven't had any luck in my reading of it.
Old Feb 24, 2023 | 04:34 PM
Blue Bucket List
Ok, that does present some issues that I'm not that qualified to help with. Did you just do the swap and started having these problems or did it run fine for a while and then started to act up? I'm not sure if the LT4 uses all the same sensors as a 94 LT1 so maybe someone else who has gone down this road will jump in and try to give you some help.
To Hard Start
