Help
Old Feb 27, 2023 | 11:15 AM
Vets-Vet's Avatar
Vets-Vet
Default Help
Intake gaskets were set and ready to go and then nothing from the permatex can with a trigger. Can someone please explain to me how to get these crap permatex trigger nozzles to work. I turned it counterclockwise as instruction and nothing.
Old Feb 27, 2023 | 11:55 AM
Vets-Vet's Avatar
Vets-Vet
I had to strip all of the nozzle pieces off of the can down to the last plastic piece and bend that tube to apply it.
Old Feb 27, 2023 | 12:06 PM
pedricd's Avatar
pedricd
If it is the can with the trigger, you unscrew the center white plastic nozzle a couple of turns and it should work. The nozzle then screws back down when done.
In other words you do not spin the trigger with the nozzle.
Old Feb 27, 2023 | 12:20 PM
Vets-Vet's Avatar
Vets-Vet
Yes, did that, read the directions before using and this was my second time using this type nozzle. First one worked OK but hardened after a month of non use, second can did not work no matter what except stripping all parts off and using the valve stem piece.
Old Feb 27, 2023 | 04:51 PM
Railroadman's Avatar
Railroadman
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
They should make that stuff in a metal can, and maybe put a small brush built into the cap. Unscrew, brush on, screw the cap back on. I bet people would buy it.
To Help
