Decoding engine numbers
Old Mar 5, 2023 | 07:18 PM
Logan931's Avatar
Logan931
Default Decoding engine numbers
I’m been trying to figure out what engine my 86 vette has I think it be a 90 but having trouble figuring it out the casting number is 14093638 the stamped number is 1G5117912 any help figuring out what motor this is would be helpful
Old Mar 5, 2023 | 07:40 PM
WVZR-1's Avatar
WVZR-1
1 = Chevrolet
G = 1986
5 = BGR
117912 = Sequence
That information should also be on the left frame rail in the vicinity of the battery.
That's considered a VIN 'derivative'. If the engine is original to the car G5117912 should be in the windshield and also on the drivers door 'Certification Label' as the last eight of the VIN.
If the first digit would have been 2 - it would have been Pontiac but since there weren't Pontiacs built in BGR we know it's Corvette for 1986.
Old Mar 5, 2023 | 07:52 PM
Logan931's Avatar
Logan931
Originally Posted by WVZR-1
1 = Chevrolet
G = 1986
5117912 = Sequence
If the first digit would have been 2 - it would have been Pontiac.
the reason I’m digging into this is the car has been rebuilt and the dash looks newer than 86 and when I’ve been looking up gasket kits for this engine the 86 kits have the valve cover gaskets bolt holes in the 4 corners and mine has the running through the middle, I just want to make sure I get the correct parts so I can get her running again g
ood
Old Mar 5, 2023 | 07:57 PM
WVZR-1's Avatar
WVZR-1
The 1986 late production did NOT have perimeter valve cover retention.
The block for sure is 1986 but maybe there's other aspects of it that could be 'other than'.
The dash is '90+. Your ECM should be under the hood above/vicinity of battery?
**** On the left frame rail in the vicinity of the battery there should be a VIN Derivative for the car.
**** 1L5xxxxxx woud be a '90 Corvette, 1N5xxxxxx would be a '91 Corvette. That information should match the windshield and also the drivers door 'Certification Label'.
***** Part # of of the fuel rails could ID other parts and the EGR if present should have a number on it.
Old Mar 5, 2023 | 08:01 PM
Blue Bucket List's Avatar
Blue Bucket List
Boy, someone went to a hell of a lot of work to transplant a 2nd gen interior into an 86. You could have later model heads that were put on when the engine was built.
Old Mar 5, 2023 | 08:08 PM
WVZR-1's Avatar
WVZR-1
Originally Posted by Blue Bucket List
Boy, someone went to a hell of a lot of work to transplant a 2nd gen interior into an 86. .
You missed ! !
Old Mar 5, 2023 | 08:14 PM
Blue Bucket List
You missed ! !
Not sure what you mean by that? What did I miss?
Old Mar 5, 2023 | 08:16 PM
Logan931's Avatar
Logan931
the door label is missing, I can’t find the number on the frame the ecm is above the battery
Old Mar 5, 2023 | 08:17 PM
Logan931's Avatar
Logan931
this car is an oddball for sure but for $800 I figured I couldn’t go wrong
Old Mar 5, 2023 | 08:19 PM
WVZR-1's Avatar
WVZR-1
You have the car titled as what? Do you have the title? The year of the chassis could be determined from the appearance of the upper control arms. The flats on an early '84 - '87 are horizontal (parallel to ground) and the later control arms are (vertical).
Old Mar 5, 2023 | 08:35 PM
Logan931's Avatar
Logan931
in Alabama any car over 35 years old doesn’t need a title, the vin says it’s an 86 but some did a lot of work to it at so
me point
Old Mar 5, 2023 | 08:40 PM
Logan931's Avatar
Logan931
no idea I must I hit something wrong on reply
Old Mar 5, 2023 | 08:48 PM
WVZR-1's Avatar
WVZR-1
So those are later '88+ control arms so the chassis is newer than '86, The A/C compressor is a 'denso and they weren't used in 1986 either.
Old Mar 5, 2023 | 08:57 PM
Logan931's Avatar
Logan931
this vette is definitely a mystery in many ways but I’m going too figure it out and get it in the road again.
To Decoding engine numbers
