engine cleaning
Old Jan 17, 2003 | 05:16 AM
sfields1's Avatar
sfields1
Default engine cleaning
hello,
i bought a 1992 lt1 and the engine needs cleaning i have heard that you should not spray the engine with water because of the optispark does anyone have any ideas?
Old Jan 17, 2003 | 07:46 AM
chucks88's Avatar
chucks88
Default Re: engine cleaning (sfields1)
hello,
You are correct :yesnod: I have an L98 engine (sans Opti) but still don't like the idea of hosing down my engine :nonod:
I use Simple Green, Q-Tips and paper towels
Old Jan 17, 2003 | 08:51 AM
DarkHalo's Avatar
DarkHalo
From: SCMR Rat Pack'r Charter Member, Inland Empire Chapter
I take my '91 (L98, no optispark) to the local self serve car wash and hose it off then break out the simple green and tooth brushes at home :blueangel:
Old Jan 17, 2003 | 09:01 AM
Greg Johnson's Avatar
Greg Johnson
Yeah, it a hand job. That is...with Simple Green and little brushes and rags.
Greg :D
Old Jan 17, 2003 | 09:40 AM
96LT4's Avatar
96LT4
Former Moderator
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
CI3 Car Show Winner
Default Re: engine cleaning (Greg Johnson)
Greg :D
Yep...I also use a small air compresor to blow out some of the biger dirt. Just be sure to wear glasses, or you'll be sorry. Just takes time and a lot of elbow grease. I also use aluminum polish on anything shiny without an ID numbr. :D
Old Jan 17, 2003 | 11:13 AM
MTVette's Avatar
MTVette
Default Re: engine cleaning (96LT4)
I use Simple Green, an old toothbrush, a small bowl of water (for rinsing the toothbrush and rinsing off the engine parts) and a big roll of paper towels. It takes a couple of hours to do a good job if the engine hasn't been detailed in a few months, but the end result is well worth the labor.
Old Jan 18, 2003 | 10:46 PM
Corvette1996LT1's Avatar
Corvette1996LT1
Default Re: engine cleaning (MTVette)
When I bought my corvette you couldn’t tell what color the motor was. I used gunk engine cleaner and then took fantastic to the plastic parts. I then went back over all of the aluminum with Mothers. I used Stoner products on the plastic to shine it up. As far as spraying the motor, I used a garden hose and let if rip. I didn't hold anything back. Key is not to spray around the water pump in front of the motor. Now keep in mind I've got a 96 which has the updated version or the opti-spark that has the vent system. I have a friend that washes his and it is a 94. He has gotten the motor to wet before and he just parked it in the sun for a few hours and it started right up. So don't panic if you do wash it and it doesn’t want to run. Give a few hours in the sun and try it. I would be very careful with the older version opti-spark when washing but it can be done.
ADDED COMMENT: I don't recommend cleaning an Lt-1 on a weekly base with a water hose but to get the engine really clean it can be done without damaging the Opti-spark. Then you can maintain it with hand cleaning and using bottled air.
[Modified by Corvette1996LT1, 3:40 PM 1/19/2003]
Old Jan 19, 2003 | 12:31 AM
jdog0411's Avatar
jdog0411
Default Re: engine cleaning (Corvette1996LT1)
Corvette1996LT1,
I must say that is one great looking vette. That engine compartment looks cleaner than new :eek:
How many miles are on your vette if you don't mind me asking?
Old Jan 19, 2003 | 01:23 AM
jimmyd's Avatar
jimmyd
Default Re: engine cleaning (jdog0411)
[QUOTE]Corvette1996LT1,
:iagree: :thumbs: good job
Old Jan 19, 2003 | 10:07 AM
DarkHalo's Avatar
DarkHalo
Yeah, it a hand job. Greg :D
must..........not..........comment
Old Jan 19, 2003 | 10:14 AM
Corvette1996LT1
Corvette1996LT1,
Thanks; it just turned 20,000 last month. I'm the second owner. The couple I bought it from used it for a weekend car so it had no sun damage but it had been driven it in the rain. I bought it for a Show car and weekend toy to drive on sunny days (I'm lucky we have a lot of sunny weather:D). I've got about 150 hours of detailing in it now and the under side looks like the motor:crazy: . However, It gets driven to ALL Car shows including Bowling Green Ky. were I had it in the National show up there this past July. That was a lot of fun!! :yesnod:
[Modified by Corvette1996LT1, 4:32 PM 1/19/2003]
To engine cleaning
