‘87 dash lights
Old May 21, 2023 | 02:32 PM
BLUDICE's Avatar
BLUDICE
Default ‘87 dash lights
The dash lights are very dim and getting worst - I have forgotten the name of the company that can repair this common problem.
And another problem I think - the dash turn light indicator both come on a stays on bright when the engine is started - what does this?
Old May 21, 2023 | 05:27 PM
ThomasR's Avatar
ThomasR
Turn signal indicator illuminated usually indicates a bulb is out. Check all the light bulbs.
Batee is the company for parts and service for instrument clusters.
Old May 23, 2023 | 10:16 PM
LiveWire1's Avatar
LiveWire1
You may have a ground problem within the display. If you open it up, look for the connecting strip of terminals. The ground is the first one, and if it's bad, you'll see the black scorch marks on it. The heat reduces the spring tension which only makes the problem worse. On my board, I soldered a jumper wire around it, with insulated spade connectors in the middle to allow the boards to still separate. Replace your bulbs with LEDs to reduce the amperage, and ultimately, the heat problem. Heat is your enemy in these displays.
Old May 24, 2023 | 09:58 AM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
When you first turn the key, is the dash brighter and then dims?
Old May 24, 2023 | 10:36 AM
QCVette's Avatar
QCVette
Active Streak: 90 Days
Is the display not working? or is it just that they are dim?
On the 84-89 dash there are replaceable bulbs that backlight the display. When they are out the dash is dim. If only one is out, it is dim in that area, but other areas may be close to normal.
You can replace the bulbs from the front in about 15 minutes.
Good luck.
Old May 28, 2023 | 06:21 AM
15 Z51 conv's Avatar
15 Z51 conv
2024 C7 of the Year Finalist - Modified
this is the place your looking for:
https://batee.com/
To ‘87 dash lights
