89 corvette seats
Old May 27, 2023 | 04:15 PM
89corvettemann's Avatar
89corvettemann
Default 89 corvette seats
Must the seat be removed from the car to remove the seat back frame from the lower cushion frame ? Thank you.
Old May 28, 2023 | 07:48 AM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
I really not understanding the question?
If you take the seat cushion in front, and push down hard, and with your other hand slide it down front frame you will feel a clip, push it down and release it, then cushion can be removed.
The back cushion push bolster in hard you will see two clips holding it in place and it will remove.
The video shows to remove the seat, no need I use to pull my seats all the time to switch positions hope the video helps.
Old May 28, 2023 | 02:26 PM
89corvettemann
Sorry i meant seperate the seat back where it pivots on the bottom portion of the seat. I dont want to remove just the back cushion from the seat , that is a nightmare to me.
To 89 corvette seats
