plastic or bronze
Old Jun 6, 2023 | 05:37 PM
rhandle's Avatar
rhandle
Default plastic or bronze
Hi ,in repairing c4 headlight motors,Would using bronze gears( i already purchased them) for the repair have ANY disadvantage over the plastic replacement gear?
Popular Reply
Jun 9, 2023, 12:28 PM
mark970's Avatar
mark970
What is one factual benefit from the brass gear? assuming the plastic gear in the car is still good (which usually they are, its the 3 pellets that tend to go bad...by design). I can name a few cons, can't think of a single pro
Old Jun 6, 2023 | 06:47 PM
Topduarte's Avatar
Topduarte
Plastic will disintegrate in time.
Old Jun 8, 2023 | 07:52 PM
Dacer Spears's Avatar
Dacer Spears
Can't think of any downside!
Old Jun 9, 2023 | 12:28 PM
mark970's Avatar
mark970
Old Jun 9, 2023 | 03:13 PM
jframe's Avatar
jframe
My gears in my 89 were both cracked acoss the middle; the pellets were perfectly fine. I figure brass will have a hard time cracking.
Old Jun 9, 2023 | 05:33 PM
mark970's Avatar
mark970
I'm not trying to stir the pot but rather let people know that bigger isn't always better.
I actually need to perform this repair in my 89' as well (it will be a winter project). I have performed this PITA job before, not looking forward to it. It's odd I think that both your gears are cracked and not the pellets...is it possible that maybe a PO performed the repair and damaged the gears ripping the motors apart (secret: the left and right motor dissamble differently in regards to removing the cover/gear...many people just "rip" it out). Here's another example of DIY...Some people can replace an opti 1 time, others replace it 3 times in 1 year
End of the day the brass gear will do it's job and you'll have properly moving headlamps.
I can't deny that the brass gear will probably outlast the car (possibly a pro, but imo irrelevant) but the factory plastic gears are :
  1. 30+ years old, they have performed well and in most cases are still fine
  2. Lighter than brass...(impacted less by centrifical force and/or momentum)
  3. The motors whip around pretty quick...I think a heavier brass gear would eventually wear the pellets down faster not to mention the actual motor
  4. There is a huge difference in price...however one could justify the price as a 1-time purchase and piece-of-mind
  5. I assume Engineers were smart 30 years ago so I also assume the plastic was by design as to not wear/destory the more expensive components of the system (worm gears, motor ect...)
For others that need to perform the job for the first time, it's not "hard" it's just a PITA. It's a borderline "not worth doing" job depending on your drive habbits and what you actually do with the car...also, be prepared to make a couple trips to Menards
Old Jun 10, 2023 | 03:49 PM
dizwiz24's Avatar
dizwiz24
Each brass gear felt like it weight 1 lb
the headlight motor/lense assemblies are already heavy AF weight on the front end
the plastic wagner headlamp reflectors are lighter, but cant see squat for the speeds these cars are capable of
i couldnt stand the idea of adding more front end weight, so i did plastic gears
Old Jun 12, 2023 | 07:39 PM
bac22's Avatar
bac22
Plastic is fine, if it's a 96 the car is 27 years old and the plastic gears lasted this long. And like the above post I seem to recall bronze gears are heavier thus putting more stress on the motor to open/close...whether the latter is true or not, don't know, but makes some sense.
Old Jun 15, 2023 | 07:35 AM
Dredgeguy's Avatar
Dredgeguy
Stay with plastic and just replace the 3 pellets, that is your problem and the items that need to be replaced.
Old Jun 15, 2023 | 08:26 AM
Dacer Spears
Well, I learned a lot from these answers!
Old Jun 21, 2023 | 02:51 AM
ElisTwoCents's Avatar
ElisTwoCents
St. Jude Donor '05 thru '24
Plastic…I’ve replaced the gears in (4) different C4s and I think 2 were the small bushings and 2 were the gear teeth themselves being chewed up. I’m not sure what the motor would do if gears were jammed up for any reason midway thru the open/close event.
Old Jun 21, 2023 | 07:08 PM
89corvettemann's Avatar
89corvettemann
burn out probably
Old Jun 22, 2023 | 09:16 PM
detroitrust's Avatar
detroitrust
I used my headlights the first time after owning the c4 for 2 years. I didn't even know they were jacked up. Not looking forward to fixing them. Have four to repairs
with the two c4s.
Old Jun 24, 2023 | 08:09 AM
vetman1's Avatar
vetman1
If you only need the bushings, save yourself some money and just order a stick of 5/16 delrin rod from McMaster Carr. It's way cheaper than any of the bushings from any of the vendors and you will have enough left over to do 20 sets of headlights.
Old Jun 24, 2023 | 07:47 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Originally Posted by vetman1
If you only need the bushings, save yourself some money and just....
...mix up some epoxy and pour it into the gear. I did this on my car, 10+ years ago....still works great. Cost pennies, and didn't have to wait for parts OR go to the store.
To plastic or bronze
