Please help
Old Mar 15, 2024 | 05:00 PM
PennyUnwize's Avatar
PennyUnwize
Originally Posted by IHBD
All those H3x codes in Module 1 can be set by low battery / system voltage.
Run my test for "Reference Pulses". It tells a lot about several things. If the fuel pump runs after cranking breifly, the ECM recognized reference pulses.
Another pretty simple check: Watch the tachometer while cranking. If it just sits on zero, there won't be spark. ICM or ECM. There could still be Reference Pulses, however.
I would wait for a Petris. There is no substitute, IMO.
so I took my battery and was told the cell is dead. Could I have killed it trying to start it so many times?
Old Mar 15, 2024 | 05:06 PM
Railroadman's Avatar
Railroadman
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
Originally Posted by PennyUnwize
Sorry, it spins but won’t turn over/crank
Read this very carefully.
If you turn the key, and the motor "goes around", that's spinning, or cranking, or turning over. All the same thing.
If you turn the key and it only goes "click", or if nothing at all happens, then it will NOT crank / spin / turn over.
Not trying to be picky, and we figured out what you meant, but this will save you (and us) confusion in the future.
Old Mar 15, 2024 | 05:39 PM
PennyUnwize
Your condescension is noted. The motor tries to start, but doesn’t. Is that better?
Old Mar 15, 2024 | 05:47 PM
PennyUnwize
The constant cranking may have given the battery the final death-blow, but it was on its way out.
Another thought:
You indicated that the SYS message was flashing when you brought the car home. This indicates there was at least one active Code in the CCM (Module 1.) I've seen correlation between "bad battery" and SYS message. You indicate you had "18 Volts" indicated. A bad battery can cause high charging current but the alternator should still regulate the voltage to the nominal 13.8-14.5-ish. But what if the regulator is also faulty and is allowing "18 volts"?
High system voltage can be detrimental to solid state electronics. Things like the Opti, ECM, and ICM.
When you go to start this car, if it starts, monitor the system voltage immediately! If you see indications over 14.5, or the voltage climbs and gets over 14.8, shut it off! Investigate that the alternator regulator is also faulty. Don't allow high system voltage to destroy new parts or take out something else.
I cannot remember for the life of me now what the voltage was while driving. I don’t think it was that high, I want to say it was somewhere around 12.8? I also may have a bad multimeter because I could swear I saw my battery had 18 volts. When I checked the codes I didn’t see anything that was a C code, everything was H. I have to wait for our torrential down pour to stop before I got and continue my investigation.
Old Mar 15, 2024 | 05:48 PM
PennyUnwize
Originally Posted by FAUEE
The number 1 water ingress point is the wiring harness. It isn't sealed, and so water will migrate right now the harness, past the pins, directly into the optical sensor.
If it was being prepped for sale, it wouldn't be surprising to hear that they cleaned the engine bay, and some water or cleaner got on the harness and killed the opti. Lots of people think covering the opti helps. It doesn't, the outside shell of the opti has a seal to prevent water getting in. The wiring harness is a direct pathway for water to get in.
Wouldn’t I have technically gotten no start from the get go if this was the case?
Old Mar 15, 2024 | 05:54 PM
Railroadman
No condescension intended, and I am not the only one who posted about the issue. We all ask for help from time to time, and we all are constantly learning new things, even after decades of working on cars. But your misunderstanding of the terms forced those trying to help, to figure out from context what your intent was. I was trying to save you from repeating that in the future. If you ask for help, have some respect for those who would help you.
I hope your problem is easily and inexpensively resolved.
Old Mar 21, 2024 | 02:33 AM
PennyUnwize
Another thought:
Would a bad ground strap cause no injector pulse?
