should the dipstick tube have an 'o' ring on it between the engine block and tube?
LT1/4 I don't believe there is
A '95 and '96 tube and indicator are different from your originals. If that's a '95 tube you should need an indicator to match.
good to know that the 92-94 doesnt have one - bc I have a 1993 also with that dipstick
For this other car I am working on,
I care about the 95-96 dipstick, as that will be the tube I use.
the dipstick tube i pulled off a 1996 camaro lt1 (which is a different tube than for corvette lt1) had an o-ring on it
Which is what sparked me to create this post.
(i wont be using that dipstick tube, but will be a using a 95-96 corvette dipstick tube that I purchased as used)
It's just a press fit. IIRC service manual says to put lock tight on it. I followed the service manual in the past and it did not leak.
No o-ring. It's press fit. I did used to spread a very tiny amount of "The Right Stuff" around the perimeter of the tube just at the top where it's flared to sit on the block as added leak insurance.
The following 2 users liked this post by 96GS#007:
'78CorvetteS.A. (03-19-2024),
dizwiz24 (03-18-2024)
