Idling Issue
Old Mar 29, 2024 | 10:42 AM
youngdieg's Avatar
youngdieg
Cruising
Default Idling Issue
Hello! Looking for any sort of help or advice with my 1992 corvette. Just recently, it has started to act up when idling. The rpms are fluctuating, and it will stall. This only happens when it is sitting for 5 minutes or more, besides that it still drives great.
Any sort of help to get started on addressing this issue is much appreciated. Thanks!
Old Mar 31, 2024 | 05:49 PM
96GS#007's Avatar
96GS#007
Check all the usual stuff.
  • Fuel pressure
  • Fuel Pressure Regulator
  • Injector ohms (hot and cold)
  • Plug Wires
  • Plugs
  • Make sure the IAC valve isn't coked up
  • Verify the EGR valve operates
  • Scan it and see what the o2 sensors are saying
That's a good start before diving deeper.
Old Mar 31, 2024 | 06:03 PM
youngdieg's Avatar
youngdieg
Cruising
  • Fuel pressure
  • Plug Wires
  • Plugs
Thank you! I got code 16 on my ecm, so I think it is an optispark issue. Please let me know if you have any further advice!
Old Mar 31, 2024 | 06:21 PM
96GS#007's Avatar
96GS#007
16 is the low res signal from the Opti and typically indicates it's on the way out. Might want to disconnect and then reconnect the harness that goes to it as well as the coil wire. Then reset the code and see if the symptoms persist and the code returns. If it does, you can look at it on a scanner and verify what's going on or start shopping for a new opti.
Old Mar 31, 2024 | 06:29 PM
youngdieg's Avatar
youngdieg
Cruising
Thank you! What exactly is the coil wire and where is it located? Sorry I’m a newer corvette owner trying to fix this issue without taking it to a shop.
Old Mar 31, 2024 | 07:20 PM
96GS#007's Avatar
96GS#007
Looks like a spark plug wire. Runs from the ignition coil on the front of the passenger side cylinder head to the optispark.
Old Mar 31, 2024 | 10:03 PM
youngdieg's Avatar
youngdieg
Cruising
Thank you I really appreciate it!
To Idling Issue
