Traction control makes my engine stall out
Old Apr 3, 2024 | 04:44 PM
1993burgandy's Avatar
1993burgandy
1st Gear
Default Traction control makes my engine stall out
I was driving the other day and messing with buttons since I just picked up my 1993 c4 and when I turned the traction control back on the engine stalled out so I restarted the car and turned traction control off then back on and it shut off again any ideas where to start?
Old Apr 3, 2024 | 08:31 PM
eawatling's Avatar
eawatling
Have you looked into it at all? Is your throttle cable moving when you engage it? Is your voltage spiking at all? Are you having any issues with throttle response? I would check the cable first.
Old Apr 4, 2024 | 08:13 AM
Whaleman's Avatar
Whaleman
On my 96 every time I start the engine the traction control turns on. I can turn it off but if I stop the engine and restart it will turn back on. You can not turn it off and have it stay off. Are you sure you are turning it on or off? Every time you start the car it is on. Not possible to start the car with it off. Dan
To Traction control makes my engine stall out
