Replacement Sunvisors - Two questions.
Old Apr 13, 2024 | 05:03 PM
97SLVRC5's Avatar
97SLVRC5
Default Replacement Sunvisors - Two questions.
Hello all,
I ordered replacement visors - two questions:
  1. Is there any reason not to use the old spring and retainer?
  2. Will the electrical connection pull through the opening for the sun visor post, or do I need to disassemble the windshield trim and dig for it?
Car in question is a '93 convertible.
Thanks in advance!
Old Apr 13, 2024 | 07:00 PM
slammin's Avatar
slammin
Have you removed the old visors? If you haven't you should be able pull the wires down to unplug. Do the reverse to assemble. I bought new visors for my 91and haven't installed them yet. I had to change the front targa mounts because Bubba put a mid year top on the car and attached it with zip ties! It was cheaper to do that than scour the country for the correct top, pay 6 to 800 dollars plus the cost of having it shipped.
Old Apr 13, 2024 | 07:16 PM
97SLVRC5's Avatar
97SLVRC5
Thanks! I just bought the car - the visors look original and I have not removed them yet. I'll try to dismount the assembly and reuse existing parts.
Old Apr 14, 2024 | 11:46 AM
BillDurant's Avatar
BillDurant
I just took off the old crappy visors and have none
Old Apr 14, 2024 | 02:31 PM
97SLVRC5's Avatar
97SLVRC5
Lol, I thought about doing that as well. Although, job is complete - after watching a couple videos and understanding how simple it actually is, it probably took me a total of 20 minutes to do the actual work.
Old Apr 14, 2024 | 09:46 PM
Corvette_Dez's Avatar
Corvette_Dez
Zip ties and duct tape fix everything!
Old Apr 14, 2024 | 10:58 PM
slammin's Avatar
slammin
When I pulled down the visors and saw the zip ties I thought Bubba must have stripped the threads. Nope, wrong top! I found the correct mid year mounts and header trim at small yard across the street from my shop.
To Replacement Sunvisors - Two questions.
