Digital Dash
Old Apr 25, 2024 | 09:05 PM
ChevyGirl0027's Avatar
ChevyGirl0027
8th Gear
Default Digital Dash
May be a dumb question… I’m considering taking out my digital dash on my ‘87 Vette and having it redone with new lights. What i’m wondering is can you take the digital dash cluster out without taking out the vehicles odometer? Or is that one piece attached to the cluster?
Thank you
Old Apr 25, 2024 | 11:06 PM
2011KLR's Avatar
2011KLR
Theyre together in the same unit.
Old Apr 26, 2024 | 10:55 AM
conniekalitta's Avatar
conniekalitta
Thank you
They both come out as one whole unit. The odometer is screwed into its own little section in the corner, connected to the rest of the cluster via a little cable.
Old Apr 26, 2024 | 11:13 AM
Kjdad's Avatar
Kjdad
All one. If just changing the bulbs you don't need to remove unless you are changing the bulb sockets as well.
Old Apr 26, 2024 | 11:36 AM
BillDurant's Avatar
BillDurant
https://batee.com/
Old Apr 26, 2024 | 05:25 PM
MrRenoman's Avatar
MrRenoman
I agree with BillDurant, go with Batee if you're going to have it rebuilt. A friend of mine just had his done, he liked it and the price.
Old Apr 27, 2024 | 07:52 AM
PAINTER MAN's Avatar
PAINTER MAN
You can pull the cluster and change the bulbs and sockets and reinstall in about 2 hours taking you time. I replaced mine with LED’s. The light is much better and no heat on the cluster.
Old May 2, 2024 | 07:33 PM
Faceman89's Avatar
Faceman89
Agreed. I pulled the cluster on my 89 and installed LED bulbs form Batee. Best interior upgrade I did.
Old May 5, 2024 | 08:03 PM
64Scout's Avatar
64Scout
I put LEDs in mine, and the only downside is that they don't dim. Either that, or my dimmer doesn't work.
Old May 5, 2024 | 08:35 PM
Faceman89's Avatar
Faceman89
Said the same thing when I put them in mine. They just don’t dim.
Old May 5, 2024 | 09:12 PM
Kjdad's Avatar
Kjdad
I wish there was a low heat oem style bulb as an option.
To Digital Dash
