Instrument cluster
Old May 12, 2024 | 10:15 PM
Adam2980's Avatar
Adam2980
Default Instrument cluster
My instrument cluster is not lighting up when I turn on the car. Besides the fuse, are there any other possible issues that could be causing it. Also, is the theft deturent connected to the power for the cluster?
Old May 13, 2024 | 03:05 AM
ls777z's Avatar
ls777z
Year? Bad ground, worn/burned out circuits, loose connection, and others. If I understand your reason behind the second question, the answer is no, the anti-theft system is not the reason your gauge cluster isn't working.
Old May 13, 2024 | 10:37 AM
N227GB's Avatar
N227GB
St. Jude Donor '14 thru '20, '23 thru '26
Make sure to check the ground point for the harness under the engine. Clean it with Deoxit and a brass or stainless steel brush.
To Instrument cluster
