Vandalized need help
My 89 was vandalized outside my house last night they tore out the steteo broke down the kickpanel and tore a couple tods out. The shifter can move without the key in now and i cant start it. Thid one rod was laying on the floor and its all bent. One rod is pulled out from inside yhe column and if I pull it the dash lights up but cant get it to do anytbing else and I dont know how it goes back in the column.
I found out I can start the car with the key in by oulling on the rod they pulled out of the column but I cant turn the steering wheel if I can get a way to be able to turn it I can at least drive it to hve it fixed somewhere
That sucks! Sorry to see this
jv9999 (05-20-2024)
Why are you trying to drive it someplace?
I dont have comprehensive insurance I can actually start it but cant drive it I guess ill have to have it towed to a shop to fix it
Someone please help tell me what parts I ned to get or something the key will not turn is that because this rod is out for the love of corvettes someone help
it looks like it might be the headlight dimmer rod if it is that isnt why my key wont turn anymore is it
Depending upon what was done with the actual ignition switch, the lock pin might be jammed and not allowing the steering wheel to turn. Remove the steering wheel and pull out the lock cam.
