Ecm
Old Jun 26, 2024 | 01:21 PM
88 cab's Avatar
88 cab
5th Gear
Default Ecm
Hello,
one question, will a ecm from a ‘91 work on a 88. They are both automatic
Old Jun 26, 2024 | 02:53 PM
ULTM8Z's Avatar
ULTM8Z
No. I believe 90-91 are different than earlier ones. MAP vs MAF based EFI systems among other things.
Old Jun 26, 2024 | 02:56 PM
88 cab's Avatar
88 cab
5th Gear
ok,thanks
Old Jun 26, 2024 | 03:01 PM
88 cab's Avatar
88 cab
5th Gear
it does some wierd things. the fan starts with the ignition on, like it is in diagnostic mode. when i put the paperclip in it wont give codes. The car starts but stops after a few seconds. sometimes it will run high on idle but stops if put in gear.
Old Jun 26, 2024 | 03:50 PM
ULTM8Z's Avatar
ULTM8Z
Could be just the internal PROM module rather than the entire ECM.
Old Jun 27, 2024 | 05:42 PM
2cam's Avatar
2cam
It sounds like we may be having some of the same issues. When the fans come on, is your SES light on? Is it back-firing through the intake if you press on the gas before it stalls/dies?
2cam
Old Jun 28, 2024 | 02:51 AM
88 cab's Avatar
88 cab
5th Gear
Yes, the ses light is on and it’s backfireing thru the intake, so I think we got the same problem.
Old Jun 28, 2024 | 04:13 AM
88 cab's Avatar
88 cab
5th Gear
It’s like carbureted engine without choke
To Ecm
