C4 rear window
Old Jul 15, 2024 | 03:23 PM
gern511's Avatar
gern511
2nd Gear
Default C4 rear window
My rear window has a clear film that is coming loose. Where it is no longer there it is hazy. Can anyone tell me what to use to remove the haze?Also can anyone tell me how to remove the rest of the film which is still intact.
Old Jul 15, 2024 | 04:48 PM
flannel_man's Avatar
flannel_man
Cruise-In VI Veteran
Ugh. Just had to remove the peeling tint on mine a few weeks ago. Get a good razor blade scraper and at least a dozen blades. Then open up the elbow grease and git r dun. Sprayed goo gone and Windex on it after the film was off to get all the residue off. Planning on getting the whole thing UV ceramic tinted once my project list dies down some
Old Jul 15, 2024 | 05:11 PM
jv9999's Avatar
jv9999
Be careful of your defroster wires. The wires themselves and the coating on top of them. Personally, I would use a heat gun to soften the adhesive as I go.
Old Jul 15, 2024 | 08:30 PM
David10's Avatar
David10
Cruising
Hello -
I had a tint shop remove the film/glue from the rear window in my 96 Corvette. The orange lines remain - is the defrost wiring in the glass or were there wires glued to the glass?
If the wires are not inside the glass and are now gone, is there a replacement kit available for the wires?
Thank you -
Dave
Old Jul 15, 2024 | 11:00 PM
jv9999's Avatar
jv9999
Originally Posted by David10
Hello -
Thank you -
Dave
The wires are on the inside of the glass. A tint shop should know to not damage the wires. I don't know of a kit to replace them.
Old Jul 15, 2024 | 11:15 PM
David10's Avatar
David10
Cruising
Default Rear Defrost
Thank you - If the wires are on the inside of the glass then all is well!
Dave
Old Jul 16, 2024 | 08:53 AM
radar502's Avatar
radar502
Steamer ,the steam and the heat loosens the glue makes it easy to remove the same for old tent. that is what they use at the tent shop .. I watch them do it .. So went home did the same .. Decals same steamer ..
Old Jul 16, 2024 | 12:59 PM
ToniH's Avatar
ToniH
The rear defroster wires are on top of the inside surface of the glass, they are not inside the glass itself. Try them with your finger, you should feel them. If your tint was on the outside surface of the glass then removing it could not effect the wires.
Aren't there 2 connectors in the wires? Haven't looked myself for a decade. But if there are you could test if the wires are still good with a multimeter. Check continuity between the 2 connectors.
Old Jul 16, 2024 | 09:47 PM
flannel_man
One of the few times having no rear defroster has been a positive thing
Otherwise yeah, probably a lot different for removal with the wire grid
To C4 rear window
