ABS problems
Old Aug 12, 2024 | 01:33 AM
Bob Fanning's Avatar
Bob Fanning
2nd Gear
Default ABS problems
My 1994 C4 has gotten me in an accident. For no reason the ABS system activates and the brake pedal goes right to the floor. It usually happens when I am coming to a stop sign or red light. The last time it did this I rolled into a Lexis and did some damage to the Lexis. Strangely enough there was no damage to my Corvette..I figured it was a bad sensor so I pulled the fuse for the ABS so I could drive it and not worry about getting in any more accidents. I took it out for a drive and it still did it again. What else do I have to disconnect to disable the ABS so I can get some use out of the car before winter settles in. In New York the ABS does not have to work to pass inspection. What else do I have to disconnect to eliminate the ABS system?
Old Aug 12, 2024 | 02:24 PM
Elduderino's Avatar
Elduderino
Welcome to CF! Whoa, thats a bit of a problem you got there. I went a few rounds with the ABS in my 96, but yours is a little different I believe. At first gance though, ID say your infor a mechanical ABS "delete". How are you at plumbing?
Old Aug 12, 2024 | 03:17 PM
Bob Fanning
2nd Gear
I'm not very good at plumbing. If I am reading you right I will need to remove all the ABS equipment to insure this condition stops. Thats a little above my pay grade. I will have to find someone qualified to take on that task. Thanks for the possible solution.
Old Aug 12, 2024 | 03:24 PM
ChumpVette's Avatar
ChumpVette
How long have you owned this car?
Current mileage?
Known maintenance?
ABS delete, you’ve got to be sh!tting me.
Old Aug 12, 2024 | 06:50 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Your problem isn't an ABS issue.
When ABS activates to prevent the wheels from locking up during a panic stop, the pedal does not go to the floor.
If your brake pedal is going to the floor, you have a fluid issue.
Either air in the system, or some kind of leak. The leak could be internal to the master cylinder, so you may not actually see the leak.
Old Aug 12, 2024 | 06:54 PM
Whaleman's Avatar
Whaleman
Is this maybe ASR and not ABS? Dan
EDIT:
Bing Videos
I just wonder if you have air in the ASR rear brake automatic system.
Old Aug 12, 2024 | 10:10 PM
CorvetteRules's Avatar
CorvetteRules
I agree with RollaMo-LT4 , if the peddle went to the floor it isn't the ABS. You have some type of fluid issue, maybe a brake master problem.
To ABS problems
