C4 Corvette
Old Sep 4, 2024 | 05:53 PM
MikeC27's Avatar
MikeC27
4th Gear
Default C4 Corvette
So after I installed all new brake pads and rotors Everything works good but only the driver side rear brake makes a grinding noise when I take off and stop anyone know what this can be it never did it before I installed all new brakes and rotors. Thank you
Old Sep 4, 2024 | 06:08 PM
ls777z's Avatar
ls777z
did you accidentally bend the dust shield?
Old Sep 4, 2024 | 07:18 PM
Purple92's Avatar
Purple92
Best advice I can give you is to jack up the rear end - put the car in neutral and spin the wheel by hand. See if you can identify what's making the noise. There are numerous things it could be: Warped or improperly installed rotor, bad wheel bearing, bent dust shield - etc...
Old Sep 4, 2024 | 07:58 PM
MikeC27's Avatar
MikeC27
4th Gear
Thank you for the info I figured it out
Old Sep 5, 2024 | 07:01 AM
kenmohr's Avatar
kenmohr
Well what was it
Old Sep 5, 2024 | 07:27 AM
mazdaverx7's Avatar
mazdaverx7
I'm also curious what you found.
Old Sep 5, 2024 | 09:29 AM
Elduderino's Avatar
Elduderino
Is it the ABS cycling itself at the first time its moved after startig? This would only happen once fter starting and it starts at 4 MPH
Old Sep 9, 2024 | 08:13 PM
larrybud's Avatar
larrybud
I recommend changing the title of the thread to the actual question and posting the fix so others in the future can easy search for similar problems. Just posing "c4 corvette" as a title doesn't give any information.
Old Sep 11, 2024 | 12:30 PM
kael's Avatar
kael
Finalist 2020 C4 of the Year - Unmodified
2nd.
OP, do your job and help others later, like they helped you!
To C4 Corvette
