A/C-heater control problem
Old Feb 4, 2003 | 07:21 PM
1990white's Avatar
1990white
Default A/C-heater control problem
Hi there. I live in Carlsbad, CA and I'm new to the Corvette world. I do have a 350 in 1940 Ford Street Rod.
? is. The A/C in my 1990 works great including the automatic temp. But, when I go to use the heat, I have to put the temp up to the max setting of 90 degrees to get any heat. Any suggestions? Thanks
Old Feb 4, 2003 | 07:53 PM
Eric 96's Avatar
Eric 96
Default Re: A/C-heater control problem (1990white)
Move farther south, and don't use the heat!!!
Old Feb 4, 2003 | 10:15 PM
1990white's Avatar
1990white
Default Re: A/C-heater control problem (Eric 96)
Not a bad suggestion, but Carlsbad is not a bad place to live. So, I will spend a few cold mornings awaiting an owner who knows more about these cars than I do. Which is most everyone.
Old Feb 4, 2003 | 10:19 PM
2012 coupe's Avatar
2012 coupe
I believe there are a couple of fixes for your problem in the "Tech" section.
:flag
Old Feb 5, 2003 | 12:23 AM
pablocruise's Avatar
pablocruise
Welcome aboard, glad ya could join.
This topic comes up quite abit. Click the following link. You'll eventually see my response to the original poster of that thread. Click the links in my response for more details.
http://forums.corvetteforum.com/zerothread?id=483219
goodluck.
:cheers:
[Modified by 89 Paul in Cal, 9:30 PM 2/4/2003]
To A/C-heater control problem
