help
Old Oct 9, 2024 | 02:24 PM
judy marie's Avatar
judy marie
Default help
my 1985 corvette run very rich i have smoked the engine no vacuum leaks my mt2500 iac count is at 144 i have replaced maf senser iac sensor plugs wires temp sensor !!!!!
Old Oct 9, 2024 | 02:37 PM
2011KLR's Avatar
2011KLR
Does it otherwise run well or does it sputter and sometimes try to die on you? if so, it could be a leak in the FPR diaphragm.
Is everything else tock? Maybe it has non stock injectors, dropping too much fuel?
Old Oct 9, 2024 | 02:56 PM
judy marie's Avatar
judy marie
replaced fpr installed injectors with bosch 0280155715 everthing is stock ecept air inj syster removed
Old Oct 9, 2024 | 03:44 PM
judy marie's Avatar
judy marie
runs very bad
To help
