Obd adaptor
Old Oct 16, 2024 | 08:05 AM
glbeauchamp's Avatar
glbeauchamp
Default Obd adaptor
Will an obd2 code reader read without an adaptor on a 94? If it won't, is an adaptor available? An obd 1 adaptor will not fit. Prefer not to use the paper clip method. Thanks in advance.
Old Oct 16, 2024 | 09:37 AM
WVZR-1's Avatar
WVZR-1
Even the very expensive diagnostic tools that can do what you're wanting to do require quite expensive and intelligent adapters to work. The DIC in the car for a '94 for the average owner I'd think the better choice than relying on inexpensive readers and adapters. Fabricate your self a couple correctly terminated jumpers to use or maybe invest in a couple correct mating connectors and do your own fabrication that you could plug in vs search for pinning.
A Delphi/Aptiv# 12110252 would be a mating connector to the DLC in the car and buy several Metri-Pack 150 mating terminals and fabricate as you wish. The 12110252 is inexpensive enough and the terminals also that you could fabricate 1 for each jumpering option.
Terminals for the 12110252 I believe I'd use the 12047581 and that seems to be the suggested also. That terminal also for just jumpers OK too.
There are better than a dozen vendors out there with stock.
Old Oct 16, 2024 | 11:44 AM
CorvetteRules's Avatar
CorvetteRules
I use an Acton 9690 Elite AutoScanner that does obd I and II, that also can stream data. Unfortunately Actron no longer makes scanners, but you may be able to find one on Ebay or Anazon.
Old Oct 16, 2024 | 01:18 PM
glbeauchamp
Thanks to both you guys. SAVE THE WAVE!!
Old Oct 16, 2024 | 03:15 PM
Vets-Vet's Avatar
Vets-Vet
Just my confused little brain here, I thought 94 was OBD1 but had the OBD2 connector ??
Old Oct 16, 2024 | 04:37 PM
CorvetteRules
That is correct, obd1 until 1996.
Old Oct 21, 2024 | 07:43 AM
AndiD's Avatar
AndiD
Navigator
Use the paperclip! Works like a charm!
Old Oct 27, 2024 | 04:41 PM
7T1vette's Avatar
7T1vette
Paper clip is pretty simple. Maybe you can put a piece of graphite wrap on the clip to dress it up and feel better about using it.
To Obd adaptor
