Question for Automatic Owners
Old Oct 28, 2024 | 03:07 PM
OneRedVette's Avatar
OneRedVette
Default Question for Automatic Owners
How hard does your car creep forward at an idle?
I have a 110% stock 1995 auto and this car creeps forward unlike any other auto I've driven. It idles at 600 with AC off and a little higher with AC on.
This isn't an issue, its just surprising and I'd like to know how other C4's act.
I live in the mountains and I have yet to encounter a hill/stop light this car can't idle up.
Old Oct 28, 2024 | 04:19 PM
7T1vette's Avatar
7T1vette
Has the transmission been changed or rebuilt? Sounds like too low of a stall speed on the converter.
Old Oct 28, 2024 | 04:21 PM
IHBD's Avatar
IHBD
Pro Mechanic
You sure it is idling at "600"?
Old Oct 28, 2024 | 04:22 PM
OneRedVette
I agree on the converter stall.
Transmission is untouched that I know of. No witness marks under there. Not in it's maintenance records either.
I can still load it up to 2000 1500 rpm.
Old Oct 28, 2024 | 05:18 PM
ChiliPepperGarage's Avatar
ChiliPepperGarage
Mine is only 100% stock but it doesn't creep at idle at all. Does it sound like it is idling at 600 RPM? How are your brakes?
Old Oct 28, 2024 | 05:21 PM
OneRedVette
I had no idea I could check it with my HVAC display. I'll be doing that shortly.
Brakes are spot on.
Old Oct 28, 2024 | 06:27 PM
ULTM8Z's Avatar
ULTM8Z
I was running a factory Corvette converter in the 700R4 in my Camaro for a long while. I remember it wanted to creep forward (albeit I was idling around 650 rpm). I'd have to hold the brake a bit firmly to keep it from wanting to creep forward. The Miniram intake didn't like to idle lower than that, as it would start idling rough.
I also couldn't stall it any higher than about 1700-1800 rpm...
But when I changed to my current 2500 rpm converter, that completely went away.
Old Oct 28, 2024 | 07:48 PM
OneRedVette
Warm idle in gear is 575-625 according to hvac
Also my converter stall is closer 1500 rpm.
Old Oct 29, 2024 | 03:20 PM
IHBD's Avatar
IHBD
Pro Mechanic
Does your car have the G92 Optional Axle Ratio?
Old Oct 30, 2024 | 09:48 AM
OneRedVette
It has the 3.08 ratio rear.
Old Oct 30, 2024 | 11:10 AM
GREGGY446's Avatar
GREGGY446
Mine does want to creep. I have an occasional idle surge that makes it worse around 700rpm. Normal is about 600 for it and creeps a smidge there too.
Old Nov 1, 2024 | 01:17 PM
b_willmon_'s Avatar
b_willmon_
I want to say mine will move at 5mph or so just on creep, but on the one hill up to work every day its just strong enough to pull it very slightly upward - I still need gas to actually get up and over.
Old Nov 1, 2024 | 01:21 PM
OneRedVette
Mine will gain enough speed at idle to shift into second.
Old Nov 1, 2024 | 02:24 PM
USAF1's Avatar
USAF1
Mine creeps big time. Tach shows idling at about 500, creep indicates higher unless its a stall speed issue. As far as I know trans never been touched said PO of 24 years (female Dr.). Randy
Old Nov 1, 2024 | 08:27 PM
b_willmon_'s Avatar
b_willmon_
How interesting - not to beat a dead horse, but I was out earlier and wanted to see how fast I could get on creep : 18mph! And I do believe it also shifted into second.
Old Nov 1, 2024 | 08:49 PM
OneRedVette
Sounds pretty normal for these cars. Good to know!
I wonder how the 700R4 cars act.
To Question for Automatic Owners
