Windshield Wipers
Old Feb 6, 2003 | 05:45 PM
jlsru's Avatar
jlsru
Cruise-In V Veteran
Default Windshield Wipers
Just got back froming washing my car while at the wash I turned on yhe wipers and they would not work.Turned them to high position and they worked turned them off then back on now they do not work.When in the high position they will come out about 3 inches and back down continously.
thanks for your help
Old Feb 6, 2003 | 06:03 PM
Mikez40's Avatar
Mikez40
Default Re: Windshield Wipers (jlsru75)
If this is on your 86, then more than likely its the windshield wiper switch in you door. I had that same problem on my '86.
Old Feb 6, 2003 | 06:20 PM
vader86's Avatar
vader86
Default Re: Windshield Wipers (Mikez40)
I have the same problem, its either the motor or the switch, i confess that i havent gotten around to fooling with it yet.
Old Feb 6, 2003 | 06:44 PM
jlsru's Avatar
jlsru
Cruise-In V Veteran
Default Re: Windshield Wipers (vader86)
Thanks Mikez40 and Vader86 for the replies.I will give the switch a try first.
Old Feb 6, 2003 | 09:45 PM
HG's Avatar
HG
Ok, that makes three of us having the same problem.. I think you'll find the switch is ok.. There are two plugs on the motor. As you look at the wiper motor from the front, pull off the connector on the right side of the motor and be sure it's clean and dry. When i moved the connector, mine began to work..It it was over 25 degrees outside, I would have gone further with it.
Old Feb 6, 2003 | 11:17 PM
jlsru's Avatar
jlsru
Cruise-In V Veteran
Default Re: Windshield Wipers (HG)
Thanks HG I will try htat too.
Old Feb 7, 2003 | 03:24 AM
BlackbirdZ07's Avatar
BlackbirdZ07
I had the same problem. If you look in the factory manual there's a chart with common problems and most likely causes. The most probable cause for "wipers cycle in and out of park position" is a faulty park switch. This is a small part inside the motor itself, and it's easy to change. Mine would only work on high, and then would only cycle in and out of park. They'd only go up a few inches and come back down. I replaced the park switch and it fixed the problem. I got mine from http://www.tld-corvette.com for $37.
Old Feb 7, 2003 | 02:51 PM
vader86's Avatar
vader86
Default Re: Windshield Wipers (BlackbirdZ07)
How do you replace the wiper switch in the door? Do you have to take the whole panel off?
Old Feb 8, 2003 | 09:29 PM
vader86's Avatar
vader86
ttt
To Windshield Wipers
