Hood release cable
Old Dec 27, 2024 | 03:51 PM
johnfin's Avatar
johnfin
Default Hood release cable
Does anyone sell the cable ends?
Old Dec 27, 2024 | 09:49 PM
ajp01's Avatar
ajp01
Not that I know of, the full cable assembly for both sides is sold as one unit.
But yours is easily fixable. All you need to do is slide the cable end out of the latch mechanism (rusty part at the bottom), and then super glue that black end cap back onto the hex adjuster piece. I'd suggest a gel-type super glue. Just try to avoid getting too much on the cable itself.
The black disc part you're gluing back on isn't under a lot of load normally, all it does is locate the hex adjuster properly in that slot where it presses against the latch. That hex part is loaded in compression when you open the hood latch, it doesn't get loaded in tension with any great force.
Old Dec 28, 2024 | 12:54 PM
Corvette_Dez's Avatar
Corvette_Dez
What he said, except I would suggest JB Plastic Weld as it's really easy to control where it goes and what it goes on.
To Hood release cable
