Smog delete
Old Jan 31, 2025 | 06:55 PM
johnfin's Avatar
johnfin
Default Smog delete
When you guys to a smog delete, pump, egr, o2 do you just remove the dash bulb so you dont see the error codes?
Old Feb 1, 2025 | 10:52 PM
jv9999's Avatar
jv9999
Deleting the O2 would be very bad unless you're planning to replace the entire intake and electronics package. Deleting the EGR does nothing for performance. Deleting the air pump might buy you 1 HP, easier to just vent it to free air.
Old Feb 2, 2025 | 09:17 AM
ULTM8Z's Avatar
ULTM8Z
You'll want to disable them in thr calibration too otherwise you'll get trouble codes and other quirky behavior.
But as was said, do not delete the o2 sensor. That is not a "smog" device
Also what's the reason for wanting to do that? As stated it doesn't buy you any measurable benefit.
To Smog delete
