Lost ignition keys.
Old Feb 25, 2025 | 01:45 AM
Morgs's Avatar
Morgs
2nd Gear
Default Lost ignition keys.
I have lost my ignition keys for my 96 C4.
I live on an island in the Pacific, and don't have access to any type of after market stores etc.
Security is not high on my list, so any quick/easy form of installation of a new unit would be helpful.
I have access to rock auto on line or any other helpful tips.
Cheers, Morgan
Old Feb 25, 2025 | 01:48 AM
WVZR-1's Avatar
WVZR-1
The car is titled where? Do you have valid registration?
Old Feb 25, 2025 | 01:58 AM
Morgs's Avatar
Morgs
2nd Gear
The car is titled in Vanuatu.
It has current registration.
Old Feb 25, 2025 | 08:37 AM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
No matter what you do you need the key code number, before buying new ignition cylinder or keys made.
Good luck since your on Island do they have dealership?
With your vin number the dealership if they still have the tools can cut you new set of keys!
Old Feb 25, 2025 | 10:30 AM
dburgjohn's Avatar
dburgjohn
I have had keys made with no originals available. Dealers and good general locksmiths can do with with your vin number and proof of ownership. You could probably do this via phone or internet and have the keys shipped to you.
Old Feb 25, 2025 | 10:42 AM
WVZR-1's Avatar
WVZR-1
If the ignition cylinder has been changed then the keys would be of no value! The resistance code likely is the same but there's no assurance that the keys would rotate the current cylinder. If a locksmith were contacted and could supply/confirm resistance you buy the cylinder and correct coded keys from the shop. I doubt Internet and phone would work for legitimate shop unless you were purchasing cylinder and keys for replacement.
OP - how talented are you? Do you believe you could accomplish the replacement of the cylinder yourself if you had one? It's pretty straight forward.
Old Mar 10, 2025 | 09:00 AM
1bdvet's Avatar
1bdvet
U.S. Air Force
Cheers, Morgan
So you have any updates on solving your keys problem?
To Lost ignition keys.
