quick jack - --
Old Mar 23, 2025 | 06:36 PM
sb66's Avatar
sb66
Default quick jack - --
I ma not sure if this is ok to post - but I came across this and although it is almost over - quick jack is running a 20% off spring sale - 3-400 is a fair chuck of change if you were thinking about these (some maybe - i know many prefer jack stands) - anyhow I wanted to let people know if anyone out there was thinking or on the fence about it
https://quickjack.com/
Old Mar 24, 2025 | 11:49 AM
Riley93C4's Avatar
Riley93C4
Thank for the heads up, good sale. Which model do most of you guys that have one for your c4 get?
Old Mar 24, 2025 | 12:03 PM
find1966's Avatar
find1966
I got the 5000TL a couple weeks ago for my C2. Can't believe I didn't do it 12 years ago. Fittings came already installed with thread sealer. Bought it to do a rear main seal and it was fantastic. Highly recommend.
Old Mar 24, 2025 | 12:47 PM
sb66's Avatar
sb66
I just ordered the 5000tl myself - so - I have no actual experience with it yet - read a lot of happy customers on the forum so i finally pulled the trigger
Old Mar 24, 2025 | 12:48 PM
Riley93C4's Avatar
Riley93C4
I'm tempted with my bonus from work
Old Mar 24, 2025 | 10:01 PM
typical boomer's Avatar
typical boomer
You will be glad you did.
Old Mar 24, 2025 | 11:17 PM
RPO Joe's Avatar
RPO Joe
From: Central Kansas – early 1977 L-48 Coupe in Classic White, aka the Sunset Stripper
2023 C4 of the Year Winner - Unmodified
5000TL. They're heavy; mine live on the garage floor and I park over the top of them. Installing Harbor Freight rollers makes them a lot easier to position under your frame:
https://www.corvetteforum.com/forums...post1607269382
Old Mar 25, 2025 | 05:04 AM
sb66's Avatar
sb66
very nice - like the added safety with the blocks under the wheels---
Old Mar 25, 2025 | 08:19 AM
Riley93C4's Avatar
Riley93C4
Man the sale says until 3/24 but here we are the 25th and it's still on the home page......my fingers is on the trigger
You guys use regular blocks or the pinch weld blocks?
Old Mar 25, 2025 | 09:41 AM
RPO Joe's Avatar
RPO Joe
I use the standard blocks that came with the QuickJack, they work great.
From QuickJack's website ( https://quickjack.com/pinch-weld-blocks/ ): "Supporting cars on pinch-weld rails creates excessive pressure points which can gouge or tear the standard rubber blocks and damage delicate body rails on unibody vehicles."
I haven't found gouging or tearing of the standard blocks to be an issue after multiple lifts, nor, in my opinion, do the blocks have the potential to "damage delicate body rails."
The pic is clickable.
The rubber is very grippy. The blocks deform just a bit in use and do a perfect job of "cradling" the pinch welds, without deforming excessively.
I should note that I place the blocks where the frame turns inward just ahead of the rear tires, and just behind the front tires. In fact, the lifting trays on the 5000TL model are spaced too far apart to lift the car at the factory jacking points.
Old Mar 25, 2025 | 09:48 AM
sb66's Avatar
sb66
good to note about the lifting points - thanks for that - i did not add pinch weld blocks - i have some from before and some hockey pucks just in case
Old Mar 25, 2025 | 09:50 AM
Riley93C4's Avatar
Riley93C4
I pulled the trigger and the sale was still valid, my wife's going to kill me lmao. But man doing any work will be so much easier when I need to get under it or even do brakes.
Old Mar 25, 2025 | 09:55 AM
sb66's Avatar
sb66
glad the code still worked for you! - felt the investment was worth it - and the sale helped - not sure it will help the wife thing - you may have to duck once or twice - i had the same concerns when buying it as well - i just never got as comfortable or trusting of jacking the car one side at a time - i saw the videos so I know it did - but the quick jack just looked a little easier and safer to me --
Old Mar 25, 2025 | 04:07 PM
FostersPerformance's Avatar
FostersPerformance
100% agree with all of this. Same experience here.
Old Mar 25, 2025 | 04:17 PM
find1966's Avatar
find1966
One more thing to add...I am not sure of the difference between C2 and C4 wheelbases, but watch the arc swing of the rear of the lift as it is rising. It can run into the rear wheel so just work with the spacing and carefully watch. I lay down on the ground and watch from the side as it raises. Also watch (since it swings forward while raising) that the car does not run into your garage wall or any obstructions, depending on which way you are lifting. It probably moves laterally around a foot at full lift height.
Old Mar 25, 2025 | 06:21 PM
sb66's Avatar
sb66
thanks everyone - good stuff to know - hoping mine arrives by the weekend so I will have some extra time to set up and try it out. --
Old Mar 29, 2025 | 08:57 PM
sb66's Avatar
sb66
just curious - did any users use atf fluid or hydraulic fluid to fill - seems to be a debate to which is best?
To quick jack - --
Old Mar 29, 2025 | 09:17 PM
typical boomer
I used ATF. Works just fine.
Old Mar 30, 2025 | 05:04 AM
sb66's Avatar
sb66
awesome - thanks!!
Old Mar 30, 2025 | 11:44 AM
sb66's Avatar
sb66
sorry one more ? loctite 545 thread sealant or is another better for this?
