What would this part be called and is it replaceable
Old Apr 5, 2025 | 01:19 AM
Bamcam's Avatar
Bamcam
Default Anyone know where to get this telescopic shaft or do I have to get a whole column
Old Apr 5, 2025 | 01:38 AM
WVZR-1's Avatar
WVZR-1
That's the upper shaft for '84 - '89 GM part # 7829047. What is damaged with yours? Internal threads, external threads for the steering wheel retention nut or just what? There's maybe options.
Old Apr 5, 2025 | 01:39 AM
Bamcam's Avatar
Bamcam
Inside and outside threads stripped and it's cracked
Old Apr 5, 2025 | 01:45 AM
WVZR-1's Avatar
WVZR-1
Hard to believe cracked. Where it has both external and internal threads you're saying that it's split?
Old Apr 5, 2025 | 01:50 AM
Bamcam's Avatar
Bamcam
Yessir 100% cracked but my steering wheel has play also that's why I started getting into my column hoping the play is coming from the pivot pins so I ordered over sized ones but now I'm looking at a new upper shaft but I did see some jb weld on the plastics inside that column so I'm thinking about a whole new column
Old Apr 5, 2025 | 01:51 AM
Bamcam's Avatar
Bamcam
Threads are also severely stripped
Old Apr 5, 2025 | 01:52 AM
WVZR-1's Avatar
WVZR-1
What year is your car? Your issue might NOT even be in the column per se?
Old Apr 5, 2025 | 01:53 AM
Bamcam's Avatar
Bamcam
Old Apr 5, 2025 | 01:59 AM
WVZR-1's Avatar
WVZR-1
1985
And what you call 'loose' is motion in the steering wheel turning left and right with the steering wheel?
Bamcam's Avatar
Bamcam
Left right up down so I got the over sized pins coming in but ran into this problem taking the steering wheel off I seen it was cracked
Old Apr 5, 2025 | 02:08 AM
WVZR-1's Avatar
WVZR-1
If turning the steering wheel left/right and there's 'slack' then that would be an indication that you have an issue with the intermediate shaft coupling that's under-hood and goes from the steering column to the steering rack. It takes a second set of eyes or hands to confirm the intermediate shaft is the issue. A person to turn the wheel left/right and the other to observe the coupling at the lower column to rack looking for the actual issue.
Old Apr 5, 2025 | 02:10 AM
Bamcam's Avatar
Bamcam
I will do this tomorrow and give you a reply then and thanks for telling me that part # I found it because of u
Old Apr 5, 2025 | 02:12 AM
Bamcam's Avatar
Bamcam
Would it be worth buying a new column if that's the problem? And the upper shaft being cracked also
Old Apr 5, 2025 | 02:15 AM
WVZR-1's Avatar
WVZR-1
You need to isolate the actual issue before buying anything. Where are you located? There's a few options for a fix.
Old Apr 5, 2025 | 02:16 AM
Bamcam's Avatar
Bamcam
Sudbury Ontario
Old Apr 5, 2025 | 02:18 AM
Bamcam's Avatar
Bamcam
I brought it to a shop for them to certify it and they said column ebrake seat and couple other things so I'm figuring out the column rn because that's the most expensive if I buy it out right but I don't mind trying to fix it myself to make things cheaper I ordered one part hoping it's it but by the sounds of it from you it's probably not that
Old Apr 5, 2025 | 02:22 AM
WVZR-1's Avatar
WVZR-1
Review these threads and others related to intermediate shaft coupling damage '84 & '85 with similar issues.
https://www.corvetteforum.com/forums/c4-tech-performance/3752437-1984-steering-wheel-help.html#post1591099729
https://www.corvetteforum.com/forums/c4-tech-performance/4085612-steering-wheel-has-an-excessive-dead-zone.html#post1596303787
To What would this part be called and is it replaceable
Old Apr 5, 2025 | 02:28 AM
Bamcam's Avatar
Bamcam
I will check this all out tomorrow I'm hoping this is it seems like it could be the problem
Old Apr 5, 2025 | 02:38 AM
WVZR-1's Avatar
WVZR-1
If you actually end up needing the upper shaft I part numbered for you, a C3 is the same and there were many telescoping columns in early GM Buick, Cadillac, Oldsmobile that used the same upper shaft. If there's older junk yards with many GM products maybe you find locally! Many columns have been bought up for hot rodding builds.
Old Apr 5, 2025 | 02:39 AM
Bamcam's Avatar
Bamcam
Your a gem man 💎
