1984 steering wheel help
Old Dec 11, 2015 | 06:07 AM
bam4k's Avatar
bam4k
Default 1984 steering wheel help
I tried to search for a post with my exact problem, but could not find one. That being said I hope someone can help!
In my 84 (a z51 if that matters) the steering seems fine while driving. If turn the steering wheel while the car is off (did this to change the battery) the steering wheel is now not centered while driving strait. With the car off, if I turn the wheel the opposite way about the same amount and it is centered again. Thanks for any help!
Old Dec 11, 2015 | 06:35 AM
WVZR-1's Avatar
WVZR-1
I'd say the early model intermediate-shaft coupling has failed or is severely stressed. Your situation was created/aggravated when you forced the turning with engine "off".
There are remanufactured/rebuilt available.
You actually I'd think could observe the failure if you watched the coupling while someone else cranked the wheel left/right with engine off. A really worn (yours maybe) should be visible even with the engine running and a crank left/right.
Watch the coupling at the "longer" yoke. Here's an eBay offering that you can "zoom" etc. You'll see the crimps on the longer yoke.
http://www.ebay.com/itm/1984-1985-C4...xVFD02&vxp=mtr
Old Dec 11, 2015 | 07:29 AM
bam4k's Avatar
bam4k
Thanks for the help!
Is this a "you can drive it for awhile" or "drive it and the car blows up" kind of problem?
Old Dec 11, 2015 | 08:33 AM
WVZR-1's Avatar
WVZR-1
I'd say in your particular situation it deserves "sooner rather than later" attention.
Old Dec 11, 2015 | 10:25 PM
pezter22's Avatar
pezter22
I have a '84 too with a similar problem. My mechanic said I had the same problem as WVZR stated. You can also purchase a reconditioned version from Corvette Central. Which I will do later in the spring.
http://www.parts123.com/corvettecent...50f&ukey=20892
Old Dec 12, 2015 | 04:37 PM
Hot Rod Roy's Avatar
Hot Rod Roy
The larger diameter section at the left end of the picture contains an inner rubber sleeve, which is a vibration damper. Your rubber sleeve has fractured. There are pins in the inner section that should be centered in the holes in the outer steel tube. As you move the steering wheel, notice that the pins move in the holes. These pins are a "fail safe" feature, so you can drive the car, but you'll want to replace this assembly soon.
Old Dec 13, 2015 | 01:16 AM
bam4k's Avatar
bam4k
Thank you very much for your help!
Old Dec 14, 2015 | 05:59 AM
bam4k's Avatar
bam4k
I looked in my FSM and this seems pretty straight forward and easy to swap out. Is this really the case? Any thoughts from someone who has done this would be appriciated. Thanks!
Old Dec 14, 2015 | 04:37 PM
84Z51J's Avatar
84Z51J
I have exactly this problem, to a lesser degree perhaps, and was pretty puzzled--I couldn't see the failure, or reproduce it consistently. Thank you for the time savings!
To 1984 steering wheel help
