Hot starting issues
Old May 7, 2025 | 06:45 AM
Paul Edwards's Avatar
Paul Edwards
3rd Gear
Default Hot starting issues
Hi all, I’m after some help with my 89 C4. I have an intermittent issue where the engine won’t start when at normal running temperature. I have fuel pressure and spark. I have also installed a VATS bypass to ensure that isn’t the issue.
Old May 7, 2025 | 08:50 AM
82-T/A's Avatar
82-T/A
So, the issue is... it starts fine in the morning, but after driving it around and then stopping (like at a store, whatever)... you go back outside to your car and it won't start?
What if any sounds is it making? What happens when you crank it... does it crank normally but just doesn't start? If so... then it's not the starter. Sometimes when starters get too hot, as they age, the solenoid isn't able to engage until it cools off more. They sell a starter shield for that to prevent heat soak.
But if it cranks normally, but just doesn't catch, it could be the ignition control module. When you say you have spark, are you verifying in fact that you are actually getting spark at the spark plugs? Sometimes when ICMs are about to fail... they usually stop working when they're really hot.
Just a couple of things... but need more info to help determine...
Old May 7, 2025 | 09:03 AM
pltmgr's Avatar
pltmgr
Id check the battery and its connections, the starter connections, and grounds.
Old May 7, 2025 | 03:14 PM
Vets-Vet's Avatar
Vets-Vet
I assume you mean the starter works fine but the engine won't fire. Fuel injectors most likely. Test them, if you don't know how there are plenty of videos. Test the impedance (ohms), test the operation (hear them click, open and close), then test for flow when hot. Sometimes bad injectors can be stubborn, when the engine is warm it will start but take a while. Use starting fluid to verify it is a fuel issue by pulling the PCV hose and squirting it into the intake manifold.
Old May 8, 2025 | 04:33 AM
Paul Edwards
3rd Gear
Default Thanks.
Thank you guys. Definitely not a cranking issue, the engine turns over without any issues at all.
I have spark at the end of all high tension plug leads so no issue there either.
The YouTube video was exactly what’s happening with mine. I will test the injectors and then ignition control module if required.
Do you have any recommendations for replacement injectors?
thanks again for your help.
Old May 8, 2025 | 09:07 AM
Vets-Vet's Avatar
Vets-Vet
Fuel Injector Connection LLC This is the company most reccomended here at CF. I did not go with them and regret it.
http://www.fuelinjectorconnection.com
I went with a company in New Jersey and regret it to this day. I also wish I went with stock instead of Bosch III's. If I had to do it again, I would buy the Delphi OEM 22lb replacements from FuelInjectorConnection FOR MY 87. Are you looking for all out performance or just a good running car ? My car runs a little rough to this day using Bosch III's. Some claim they are running a little lean from Bosch III's. Others like them. Are you willing to re-tune the memcal if neccassary or do you just want your vette running as it should? I do not have the Delphi's and parts quality changes quickly in todays world.
Do not take my word for it. Do your own research.
Also, in that video most of the injectors ohmed out good, so just know that test is a simple one and not always conclusive.
Old May 8, 2025 | 08:14 PM
Paul Edwards
3rd Gear
The car is almost factory but looking to make it get along a little better, very restrictive with all the emission control gear bolted to it. An after market tune is on my list of things to do along with better intake to the throttle body, extractors and full twin exhaust instead of two into one and back out to two. Hopefully that will keep the factory look with a few extra ponies under the hood.
Being in Australia and the car converted to right hand drive, not all the components in the US will fit so I need to careful of what I buy.
Old May 10, 2025 | 12:02 AM
4indog's Avatar
4indog
I had the same hot start issue and replaced the injectors in my 1988 L98 with the 22lb Bosch III. If you do this it will run lean at 40 psi (stock) fuel pressure. Change the fuel pressure regulator to an adjustable type and boost the pressure to about 50 psi or so, where it will cold start and run normally at colder (below 75F) temps. I bought my car in new in 1988 and have not noticed any change in idle or performance with the Bosch injectors vs. the original.
To Hot starting issues
