Headlight Issue - 1987 C4
Old May 19, 2025 | 03:52 PM
CiniTGS's Avatar
CiniTGS
Default Headlight Issue - 1987 C4
Hi,
The passenger headlight on my 87' keeps spinning only in the off position. If I turn the running lights on, but the headlights off, no issues. Once I turn all lights fully off, the motor keeps trying to close the headlight even though it's all the way! There's some play in the headlight which I don't remember noticing before.
I'm trying to get it Safetied on Wednesday, so I gotta get this fixed!
Here's a couple of videos that might explain it better: https://streamable.com/c/t0twvw
ALSO: The entire motor for the side was replaced last year...
Old May 20, 2025 | 06:52 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I have had no experience with my headlight motors, but it sounds like a limit switch problem.
Maybe this information from my service manual will help.
Old May 22, 2025 | 06:32 PM
RWDsmoke's Avatar
RWDsmoke
The motor can't turn if it is against the stop unless the gears are stripped or broken. To get a safety inspection just open the headlight doors and unplug the motors at the connectors. Lights will still work with the switch.
Old May 23, 2025 | 09:02 AM
CiniTGS's Avatar
CiniTGS
Ok so I opened up the motor and confirmed the gears were stripped. I replaced them with new ones but now, when closing, it makes a horrible noise! It opens perfectly fine, it's just closing. It does close all the way now though and stops where it's supposed to. Just a bad noise...
Any ideas?
Old Jun 5, 2025 | 06:33 PM
mcgin383's Avatar
mcgin383
4th Gear
I recently acquired a 1987 convert. The headlights, both the motors and the lights, (separate connectors) were disconnected.
The previous owner told me he had just replaced the motors, that there was an issue with adjustment, he just didn't have time to figure it out.
He included a box with the old motors and mechanisms.
so I plugged them in. the drivers side works fine. the lights work, the passenger side didn't move, but you could hear the motor against the stop.
I removed the pass side mechanism, to see what I could find, when plugged into the driver side it worked in both directions, but reverse of the other, it opened when it should close and closed when it should open. ( these motors look brand new and I don't think they have been opened)
My first day of Corvette repair, the headlight motors, testing the voltage at each location described in the service manual page, it all seems as it should, but no luck.
I will mess with it more tomorrow.
BTW here in Maine you couldn't get away with unplugged motors, safety inspection requires original equipment to work as designed.
Old Jun 5, 2025 | 06:52 PM
RWDsmoke's Avatar
RWDsmoke
Check and clean your grounds. Two of the relays are the same. You could try swapping them.
Old Jun 7, 2025 | 04:08 PM
mcgin383's Avatar
mcgin383
4th Gear
OK I tried switching the door relays no change, removed and cleaned the ground.
I have had the pass side mechanism in and out a few times, the motor is new and works in both directions,
on close seems like the light hits the stop and the power to the motor should stop, but it does not.
If I leave it plugged in it keeps trying to turn, I think that will result in a stripped gear and a dead battery.
The pics here show gears stripped just that way.
Is that what the Isolation Relay is supposed to do?
To Headlight Issue - 1987 C4
