Conv top repair
Old Jun 22, 2025 | 09:39 PM
1974Pantera's Avatar
1974Pantera
Default Conv top repair
I have a small tear/hole in my convertible top just below the rear glass.
Can anyone recommend a product for this type of repair?
Appreciate your help........
Old Jun 23, 2025 | 11:24 AM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
I would go to upholstery shop, and don't let them talk you into new top, just proper repair!
Old Jun 24, 2025 | 12:45 PM
Weck86's Avatar
Weck86
I also have a convertible and have restored a couple cars, so have a little experience with auto upholstery shops. And that experience is that they will not do anything with material that is still mounted (obviously can't get the material in their machines). I have not found any shop that will 'hand stitch' a repair, of course ymmv.
No matter who does it or how it's repaired it will be noticeable to some greater or lesser extent. My recommendation is to save for a new top, but while doing that suggest you get a sewing awl and give it a try yourself. Pretty sure you'll be more careful and particular than anyone else. There are various 'sealants' you can apply to the inside of your repair. Or there is always duct tape, lol (not recommended). Good luck.
Old Jun 24, 2025 | 02:22 PM
76C3forme's Avatar
76C3forme
If it's in a spot that isn't very "stressed" when closed, I normally use Gorilla Tape on the underside since it's very strong. Once I join the torn sections together , I use a little Canvas / Fabric Adhesive along the seam. It's better looking that a piece of duct tape on the outside.. When the adhesive is fully dry, It can be "touched up" to match the top color. It's noticeable when you walk right up to it, but from a distance, much better than a lot of other repairs. I just did it 2 years back to a seam on my wife's convertible. You can usually get a few years out of the repair depending on the location of the tear. (And my wife puts the top up and down about 3-4 times a day this time of year.
To Conv top repair
