Hood pop question
Old Sep 17, 2025 | 09:27 AM
MDC9966's Avatar
MDC9966
Default Hood pop question
Helping my friend with his 87 c4. When I pull the hood latch the hood doesn’t pop up an inch or so. I can raise it ok, even though it’s very heavy. It latches and unlatches fine, just wondering and can’t remember from my past 86 if it raised a bit when unlatched. The pins have springs on each side, made they need to be replaced? Thanks
Old Sep 17, 2025 | 11:46 AM
USAF1's Avatar
USAF1
I have a 96 and mine only opens an inch or so to get your fingers under it to raise it. And yes Its a little heavy getting it up. Think all that is normal. Randy.
Old Sep 17, 2025 | 03:11 PM
Vets-Vet's Avatar
Vets-Vet
The 2 assist lift supports may be weak or it may need an adjustment. The weaker the support the heavier it feels. 14043065
Old Sep 17, 2025 | 03:37 PM
car addict's Avatar
car addict
It should pop up
Old Sep 17, 2025 | 03:54 PM
MDC9966's Avatar
MDC9966
Originally Posted by car addict
It should pop up
Thanks, since it doesn't, I think the popper springs on the guide pins must be weak or need adjustment.
Old Sep 19, 2025 | 01:08 PM
RWDsmoke's Avatar
RWDsmoke
Unless the springs are broken it's most likely the latch pins are out of adjustment. If they are not centered they can drag enough to not pop up. Mine was that way for years, I had to lift the hood while pulling the release handle. After I learned how to adjust the hood latches it popped up like it should.
Old Sep 19, 2025 | 02:19 PM
MDC9966's Avatar
MDC9966
Thanks, that is great to know. Any suggestions for the right way to adjust those guide pins? Otherwise I guess I’ll get in there and just fiddle around until it works better. Thanks again.
Old Sep 20, 2025 | 10:05 AM
RWDsmoke's Avatar
RWDsmoke
I take a piece of clay and make a small ball that just fits in the latch. Then I close the hood slowly until the pin taps the clay enough to mark it. Adjust pin and repeat until centered.
Old Sep 20, 2025 | 10:34 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I need to do this. Mine unlatches but doesn’t pop up much.
Old Sep 20, 2025 | 10:56 AM
pltmgr's Avatar
pltmgr
Should it be lubed?
Old Sep 21, 2025 | 08:10 AM
RWDsmoke's Avatar
RWDsmoke
Originally Posted by pltmgr
Should it be lubed?
Yes!!
Old Sep 21, 2025 | 08:48 AM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
As Stated springs may need adjustment many vids on you-tube, just be careful not to over adjust or it will put to much pressure on the release cable and cause it to fail. First one that came up. adjust the hood release springs on a C4 Corvette, you typically don't adjust the springs themselves but rather the latch pins, which are the components that hold the hood down and are spring-loaded to pop the hood open. You can adjust the height of these pins by turning the slotted screw on the pin itself with a flathead screwdriver. Turning the screwdriver counter-clockwise extends the pin, while turning it clockwise retracts it.
Old Sep 21, 2025 | 11:29 AM
MDC9966's Avatar
MDC9966
Thanks everyone, the video really helped.
To Hood pop question
