1990 corvette problem
It’ll start if I spray starter fluid, but it won’t stay running. I let it sit for a couple of days, and now it only cranks over once before stopping. When I turn the key, it makes a really loud clicking noise and then the car “dies.” The battery is fully charged, the starter works fine, and the fuel pump is brand new.
Could this be a fuel problem or something electrical? Any ideas on where I should start looking?
The way it tends to work is you give the symptoms and folks talk through the possibles. it doesn't always go quickly - be patient.
When a suggestion is given either try it, or explain why you don't want to try it, or that you already have. But remember this. Many folks here have a massive amount of experience with these specific 30+ year old cars. They want to help but they have their own lives to live. Talk things through, be thorough in your replies - we aren't there to see things.
And my last thought... remember the car's computer is in control. It thinks that everything is still the way it was when it left the factory. Sensors that look good might not be. Connections could have buildup on them. Everything has been worn down over time. Good Luck.
"my voltage drops to zero" - if alternator is working you should have around 14.5 volts. If alternator dies it will drop to around 12.0 volts then slowly lower as battery is used. A sudden drop to zero is an open circuit. Start checking cables at battery. There is a large junction box also right beside the battery.
"start if I spray starter fluid" - you got no fuel. Bad fuse, bad relay or bad pump. Check pressure at fuel rail with a gauge then check fuse and relay with test light
"really loud clicking noise" - this is usually a discharged battery or bad starter solenoid. Starter solenoid engages (first click), amperage jumps as motor tries to run causing loose connection / bad solenoid to fail and solenoid releases (second click). Have the battery checked and put a charger on it overnight.
Good luck with your car. Post results here to further zero in on issues
