a/c pully
Old Nov 29, 2025 | 02:43 PM
spluce's Avatar
spluce
8th Gear
Default a/c pully
Does anybody make a compressor pully bypass for the 95 C4? My a/c clutch crapped out and I don't want to replace the whole a/c clutch assembly. Or is there another way of bypassing the compressor?
Old Nov 29, 2025 | 08:41 PM
82-T/A's Avatar
82-T/A
In most cars, bypassing the A/C compressor requires you to replace the A/C compressor. If you're going to do that, then why not just replace the A/C compressor? You can get a new one for a couple hundred from Rock Auto.
Old Nov 29, 2025 | 11:57 PM
arbee's Avatar
arbee
Just because the clutch took a dump shouldn't effect the pulley turning on the bearing. Explain the conditions more.
To a/c pully
