Driver side window problem
Old Apr 14, 2026 | 05:07 PM
VETTEMASTERZ51's Avatar
VETTEMASTERZ51
Default Driver side window problem
Hi everyone,
I'm having an issue with my driver side window. It goes down fine, but won't go up unless I hold the switch in the down position for about 3 seconds, then it goes back up eventually. It can't be a fuse problem. Anyone have any input on this issue?
VetteMasterZ51
Old Apr 15, 2026 | 06:14 AM
Incorvettei's Avatar
Incorvettei
Did you check the switch? Try swapping the switch with the passenger side switch and see if it works?
