Acrylic roof
Old Mar 2, 2003 | 08:52 PM
CanadaVette's Avatar
CanadaVette
Default Acrylic roof
I almost bought a 93 vette last fall after selling my 81 but what scared me off was that the acrylic roof was spider webbing at the attachment points.
Is that normal?
Is a hard roof better? Less flex?
:confused: :confused: :confused:
Old Mar 2, 2003 | 09:00 PM
vette_dreamer's Avatar
vette_dreamer
Default Re: Acrylic roof (CanadaVette)
yes and yes, and less heat getting into the car in summer. :D
Old Mar 2, 2003 | 09:33 PM
CanadaVette
Nobody has an acrylic roof?
Old Mar 2, 2003 | 09:36 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
If by spider webbing you mean hairline cracks in the arcylic then yes it's normal. If you can feel the cracks with your fingernail then it's more than spider webbing.
Look at the third pic down (click it to see the full size pic) and you'll see what most people call spider webbing. :yesnod:
http://www.corvetteforum.net/c4/blue92/targa_top.shtml
I have both and prefer the arylic top. I like the sunshine and the extra headroom you get.
[Modified by Blue 92, 9:38 PM 3/2/2003]
Light84vette's Avatar
Light84vette
I like the glass roof, it give some good visability but I never heard of webbing near the mounting spots, the directions did say not to overtighten them. ;)
Old Mar 2, 2003 | 11:01 PM
CanadaVette
Default Re: Acrylic roof (Light84vette)
Do you think the webbing is a sign of a bigger problem?
Old Mar 2, 2003 | 11:17 PM
Light84vette
It might be. Sometimes when I back out of my driveway, I could hear the glass top creak and make noise. Also my glass top has no signs of webbing and I had it on for about 8 months. I think the webbing would happen when it is tightened real tight and driven over road or courses that would cuase the body to flex. And then making the window either break or make small cracks like webbing. ;)
Old Mar 2, 2003 | 11:19 PM
Blue 92's Avatar
Blue 92
The acrylic tops flex a little but causing the problem. Normally it appearws all through the top. If it's localized by the moounting points it could mean the top mounting points aren't adusted correctly.
Old Mar 3, 2003 | 07:31 AM
beachcat's Avatar
beachcat
My 87 only has an acrylic roof. It was garage kept till 94, so she has been exposed to alot of heat here in South Florida. I have the webbing effect on mine. In the military, the jet cockpit bubbles would get fine lines on them, we called that crazed. I keep thinking I need to get a new one, but this one is lasting so far. Oh, never get that rainx stuff on it. I have a nice round spot where it ate the top coating off. As for the heat, I have the static cling, hole matrix liner on the inside of the top. No problems now for over 3 years and it keeps it much cooler while I can still see out.
Old Mar 5, 2003 | 01:24 AM
CanadaVette
Default Re: Acrylic roof (beachcat)
Thanks for the help.
Nobody with a newer vette has this problem?
Old Mar 5, 2003 | 01:36 AM
NightRyder's Avatar
NightRyder
well, i looked at lots of vette before buying mine.
most have the small cracks. and they seem to form closest to the bolts.
is it normal. well, kinda. it is normal, and unless its really bad, probably wont mean much, but its a sign that the window was stressed alot, maybe by tightening the bolts too much. or setting it down on a corner to hard. if i were to had to get a acrylic roof, id get a almost perfect one only. if only that it would extent the time i would have to get a new one and i would know how it was treated that made it become like that.
Old Mar 5, 2003 | 02:38 AM
CanadaVette
Default Re: Acrylic roof (NightRyder)
To Acrylic roof
