Power steering pump
Old Mar 18, 2003 | 10:01 AM
Preacher's Avatar
Preacher
Cruise-In IV Veteran
Default Power steering pump
I am at work, bored, waiting for info to come in so I can get back to work... so i thought I would ask.
This morning, it felt as though my power-steering were going out. I was in the bank parking lot, and twice, I had to wrench the wheel to get it to turn.
What's a new pump cost these days? Is it a job for a beginner wrench of should I just take it to the delaer?
Old Mar 18, 2003 | 07:22 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: Power steering pump (Preacher)
:cheers: You may want to try a simpler solution at first, before you spend the bigger bucks
Try changing the fluid. A big squeeze ball or a turkey baster will get most of the old fluid out of the reservoir. Fluid does go bad, it is subject to a range of heat. I use Amzoil synthetic tranny fluid in my PS and have for years. No problems, no morning sickness
:steering: [I Love that Lil Guy!]
Old Mar 18, 2003 | 07:33 PM
Preacher's Avatar
Preacher
Default Re: Power steering pump (jackdaroofer)
Hmmm... worth a shot! :cheers:
Old Mar 18, 2003 | 10:20 PM
JasonL's Avatar
JasonL
Also check your belt and tensioner. If either is too worn, the belt will slip on the PS pulley and it can feel like a dying pump.
Old Mar 19, 2003 | 06:19 AM
Preacher's Avatar
Preacher
Default Re: Power steering pump (JasonL)
I think I am good there, I just replaced the belt a couple hundred miles ago.
To Power steering pump
