Wrong, that is inaccurate assumption, it is correct most of the time but not always.
If it is convertible or a 6 speed, it probably isn't a 3.07:1 This subject is and has been covered regularly.
The only accurate way to see what it with form the factory is the other Gxx code. 3.07:1 is g44 and 2.73:1 gu2. If it is something else post and it can be dechipered.
[Modified by dgoodhue, 11:54 AM 4/2/2003]
Thats correct. I have MN6 (6 speed) also, so that invokes ratio 3.33:1
