AC Compressor keeps cycling.....HELP!
Old Mar 23, 2003 | 09:31 PM
Big Willy's Avatar
Big Willy
Default AC Compressor keeps cycling.....HELP!
When I turn on my AC or Heat, my compressor constantly cycles on and off. It doesn't matter what temperature or fan speed I am set at, it constantly
turns on and off every 5-10 seconds, causing my idle to constantly rise and fall. Any ideas?
Big *****
Old Mar 23, 2003 | 09:46 PM
bigdan's Avatar
bigdan
Default Re: AC Compressor keeps cycling.....HELP! (Big *****)
it cycles on/off for defrost/defog even in heat mode. for dehumidifying air to clear windows quicker. could this be what you're experiencing?
Old Mar 23, 2003 | 09:48 PM
flyersfan1088's Avatar
flyersfan1088
From: What did the 5 fingers say to the face? SLAP!!
You said AC and Heat. Is it actually heat or Defrost. If it's AC and Defrost you're probably low on freon.
Old Mar 23, 2003 | 09:50 PM
Rich_01659's Avatar
Rich_01659
does it cool good? the thing will cycle frequently even under normal operation. how ever it could be cycling on the low pressure, may need to check the charge.
Old Mar 24, 2003 | 08:52 AM
sumoboy's Avatar
sumoboy
Default Re: AC Compressor keeps cycling.....HELP! (Rich_01659)
:iagree:
Old Mar 24, 2003 | 09:01 PM
HG's Avatar
HG
In A/C or heat / defrost the compressor will cycle on and off if you are at idle. If it does it when running, it probably is low on refrigerant F12. Very expensive if you can find a place to purchase it. A quick way to check the charge is to put it on full A/C and measure the outlet air temperature after 5 minutes or so of driving, not idleing. This time of year, the outlet air, if the charge is correct will be somewhere in the 40 F range. If it is 50 or 60 , the charge is probably low.
Old Mar 30, 2003 | 11:03 AM
Big Willy's Avatar
Big Willy
Well, it seems that it only cycles in defrost and environ modes. It doesn't
cycle in heat and auto modes. I assume this is proper operation?
Old Mar 30, 2003 | 11:30 AM
sumoboy's Avatar
sumoboy
The clutch engages in the defrost mode to work as a dehumidifier but if it cycles as you say "on and off" it might be low on freon. Just low enough not to shut the system down by the low freon switch.
Old Mar 30, 2003 | 07:03 PM
Joel Platts's Avatar
Joel Platts
Default Re: AC Compressor keeps cycling.....HELP! (sumoboy)
Definately start with checking the refrigerant charge. The constant cycling is a classic symptom. Also have the system checked for leaks, and seriously consider retrofitting the system to R-134 if you havent already. You'll save money in the long run.
Old Dec 9, 2019 | 08:24 PM
WheelerthanU's Avatar
WheelerthanU
1st Gear
Default Big ***** did you ever resolve this problem and what did it end up being ?
Big *****
Did you ever resolve this problem? And if so what did it end up being?
Old Dec 10, 2019 | 02:45 AM
Hot Rod Roy's Avatar
Hot Rod Roy
WheelerthanU, welcome to the Corvette Forum! Unfortunately, we haven't heard from Big ***** for 10 years, so it's unlikely he'll ever answer your question. We can only hope Big ***** is doing okay. Watch for the dates of the post you are responding to, in the upper left corner of the post.
If you have a problem, start a new thread of your own. Look for the "New Thread" button at the beginning of this list. Be sure to tell us what year Corvette you're working with!
To AC Compressor keeps cycling.....HELP!
