Weird Stuff
Old Apr 6, 2003 | 11:02 AM
NBM LS1 M6's Avatar
NBM LS1 M6
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17-'18-'19
Default Weird Stuff
I've got two intermittent problems with my '90 C4 A4.
First, I have intermittent failure to be able to engage reverse gear (automatic tranny). It's like it isn't there. The key word is intermittent. When the problem doesn't occur, there is zero evidence of slippage. Up until yesterday, this problem had appeared once last weekend since I got the car four weeks ago. Yesterday, it happened a lot. I autoxed the car yesterday.
Secondly, the emergency brake light comes on when the emergency brake is not being used. This occurs for a few moments, and when I drive off, the brake light goes out not to appear again. This occurs when I start the engine. Simaltaneous to this phenomena, the power windows don't work, the stereo doesn't work, the clock radio is blank, the temperature display is blank, and probably some other power items.
What gives? Any ideas?
:confused: :confused: :confused:
Old Apr 6, 2003 | 12:09 PM
NBM LS1 M6's Avatar
NBM LS1 M6
Default Re: Weird Stuff (NBM LS1 M6)
:confused::confused:
Old Apr 6, 2003 | 12:44 PM
bigdan's Avatar
bigdan
do a search on the tech board for the dash problem. sounds like a loose ground. as to the tranny, i have no clue.
Old Apr 6, 2003 | 02:14 PM
JCAIRE2's Avatar
JCAIRE2
Default Re: Weird Stuff (bigdan)
:iagree: but that doesn't mean much in my case. I would check out the chassis ground first. :cheers:
Old Apr 6, 2003 | 04:57 PM
NBM LS1 M6's Avatar
NBM LS1 M6
Default Re: Weird Stuff (JCAIRE2)
Thanks :yesnod::cheers::yesnod:
Old Apr 9, 2003 | 02:21 AM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
My emergency brake light stays on sometimes.....until I push it really hard...then the light goe's off....I can live with it......
Have you tried to push on it after disengaged????
Try it and let me know...
thanks
tony
:eek:
Old Apr 9, 2003 | 02:43 AM
CanadaVette's Avatar
CanadaVette
I sort of had the same problem with my 81. After braking really hard I would push the gas and the car would not move. My mechanic checked it out and found the problem to be low oil in the tranny.
Check your oil.
Old Apr 9, 2003 | 04:01 AM
NBM LS1 M6's Avatar
NBM LS1 M6
Default Re: Weird Stuff (oldace84)
thanks
tony
:eek:
This problem does not occur after using the emergency brake. The problem arises when I start the engine. I am not engaging the emergency brake. The problem is intermittent. The same thing is true of the reverse gear issue. That problem has not occurred in three days. I back out of my garage each morning. No transmission slippage at all.
:confused::confused::confused::confused:
Old Apr 10, 2003 | 04:38 PM
C-4 Cross Fire's Avatar
C-4 Cross Fire
Ya bought a lemon. :nonod:
Old Apr 10, 2003 | 04:46 PM
Blue88's Avatar
Blue88
Sounds like a ground problem. Not at the battery but at the ECM where all the wires ground. I believe that mine all ground to the tranny bellhousing. Did you get any kind of history as to what work had been done on the car before you bought it?
Old Apr 10, 2003 | 07:41 PM
NBM LS1 M6's Avatar
NBM LS1 M6
Default Re: Weird Stuff (84 Cross Fire)
You won't get a lemon at Toyota of Orange.:bs
:nonod::nonod::nonod:
:lolg: :lolg: :lolg: :lolg: :lolg:
Old Apr 10, 2003 | 07:44 PM
NBM LS1 M6's Avatar
NBM LS1 M6
Default Re: Weird Stuff (Blue88)
That makes sense. I have a problem with the Air Bag light as well, and Dick Guldstrand told me that all of that electrical stuff grounds to the transmission bellhousing area. Actually, I will be seeing Dick tonight.
:yesnod::yesnod::yesnod:
Old Apr 10, 2003 | 07:46 PM
NBM LS1 M6's Avatar
NBM LS1 M6
BTW, neither problem has re-occurred in the past five days. That is one of the reasons it is weird and no doubt a problem with the grounding of electronic/electrical stuff.
To Weird Stuff
