Pulling code 42
Old Apr 12, 2003 | 02:22 PM
RUBBYRED86's Avatar
RUBBYRED86
5th Gear
Default Pulling code 42
Im pulling a code 42 on my 86 coup. The idle is running high. Itried disconnecting the EST and there was no drop in idle like there used to be? Any Ideas?
Old Apr 12, 2003 | 03:18 PM
don hall's Avatar
don hall
Default Re: Pulling code 42 (RUBBYRED86)
Access this link, then scroll to possible faults: http://www.c4vettes.com/ecm.htm
Old Apr 12, 2003 | 10:37 PM
CorvetteZ51Racer's Avatar
CorvetteZ51Racer
The code 42 is a malfunctioning ESC module. If you have a GM service manual for your 86, you can read through the diagnostics associated with the code 42, because there are a couple of possible causes. However, the most common cause is a burned up ESC module. They're pretty cheap to replace. Can't remember what mine cost, but it was under $20. Take the distributor cap off, remove the rotor, and the module is right there. There are instructions in the box for the new module to tell you how to replace it.
To Pulling code 42
