C4 Jacking & Wheel Removal
Old Apr 13, 2003 | 01:18 PM
enuf4me's Avatar
enuf4me
3rd Gear
Default C4 Jacking & Wheel Removal
Can you please help this 'mechanically challenged' C4 Vette owner preform the following.
1-Jacking/do you damage the paint when you jack at the jackpoints on the frame rails?
2-After jacking a wheel where do you position the jackstand?
3-When removing a wheel (ZR1 Chromes) how do I remove the lug nuts without scarfing up the chrome?
4-Any problem with steam cleaning the wheel wells?
Old Apr 13, 2003 | 01:43 PM
scorp508's Avatar
scorp508
Default Re: C4 Jacking & Wheel Removal (enuf4me)
1. I don't use the jack points. I use a flat piece of the frame inwards a little more. I have used them before though and my paint is fine I think. It'll make some cracking noises, but thats ok.
2. At the jack points.
3. Just be careful like any other wheel.
4. Should be fine.
Old Apr 13, 2003 | 03:17 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: C4 Jacking & Wheel Removal (scorp508)
4. Should be fine.
:withstupid:
Old Apr 13, 2003 | 08:54 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
:cheers: This may be unorthodox, but
I bought several standard C4 jacks on e bay and regularly, like every two weeks, remove either both front or back wheels.
Using the factory JACK POINTS, has never been a problem
I have installed new sway bars, C5 brakes, etc. without jack stands. I can and do lift the entire front end or the back end with no problem.
The standard jacks and Jack points are quite secure! Would GM open themselves up to lawsuits if they weren't?
Just my HO!
:steering:
Old Apr 13, 2003 | 11:20 PM
sraft's Avatar
sraft
1-I jack the car up from the factory points. I use a floor jack and put a piece of wood (an old hockey puck would be better), between the jack and the frame.
2-I put the jack stands between the jackpoints and the wheel wells, where the frame turns inward.
3-Carefully, but over time you'll end up scratching them.
4-Can't comment with certainty, so I won't.
Old Apr 14, 2003 | 12:13 AM
Torch Red's Avatar
Torch Red
St. Jude Donor '09
I need to know this too so I will sit an listen carefully so noboday has to repeat. :thumbs:
I plan to remove wheels/tires, Clean, Paint Calipers and exhaust so I am going to need to get the Corvette up somehow too ...
Please keep the input coming...
Torch :cool:
Old Apr 14, 2003 | 12:38 AM
NBM LS1 M6's Avatar
NBM LS1 M6
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17-'18-'19
One can safely, conveniently, and efficiently jack up the entire side of the car by placing a floor jack under the metal frame that runs the length of each side of the car. Place the floor jack in the middle. This should be on a perpendicular line approximately three inches forward of the top of the windshield. Works like a piece of cake. I changed my wheels twice Saturday using this method. No problem.
:yesnod::yesnod::yesnod:
Old Apr 14, 2003 | 02:42 AM
beachcat's Avatar
beachcat
At http://www.griotsgarage.com, they sell a set of impact sockets that are coated with a soft plastic to remove lugs without damaging the wheels. I have not ordered them because the space between the lug and wheel on my 87 aftermarkets is too narrow for impact sockets. I just take my time and be real careful.
Old Apr 14, 2003 | 08:02 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Default Re: C4 Jacking & Wheel Removal (beachcat)
Wrap your lug wrench with electrical tape where it comes near the wheel. I did this on mine to avoid scratching/chipping the chrome. A few wraps of electrical tape will stay on there if you don't stretch it when you put it on there, and will be soft enough to protect your wheels. :cheers:
Old Apr 14, 2003 | 08:47 AM
edsalinas's Avatar
edsalinas
St. Jude Contributor
Default Re: C4 Jacking & Wheel Removal (CentralCoaster)
Great tip! Think I'll be doing that right away.
Thanks.
:thumbs:
Old Apr 14, 2003 | 10:07 AM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Default Re: C4 Jacking & Wheel Removal (jackdaroofer)
What do you mean by standard C4 jacks????
thanks
tony
:flag
Old Apr 14, 2003 | 04:28 PM
c4md's Avatar
c4md
They make some sockets for wheel lugs that are supposed to keep you from messing up the wheels. Look here: http://www.griotsgarage.com/catalog.jsp?&SKU=77100
Old Apr 14, 2003 | 08:04 PM
Aaron71771's Avatar
Aaron71771
I use the jack point to jack the car up, usually the entire side of the car come us. I place the jackstands on the fram between the jack point the wheel, when the frame curves. This is what the factory manual recommends as well as GM. Good enough for me.
To C4 Jacking & Wheel Removal
By Michael S. Palmer | 2026-06-03 11:00:24
