Heres your answer:
Old Apr 18, 2003 | 10:10 PM
dizwiz24's Avatar
dizwiz24
Default Heres your answer:
Ok, ill be the guy with the techincal answer:
The brown color you are seeing on the sidewall is from dialkyl/ or diaryl p-Phenylenediamines leaching to the surface of the tire sidewall and reacting with ozone in the air. A small amount (maybe 1-2% by weight) of the sidewall and tread ingredients by weight is PPD (the abbreviation for the chemical named above).
This chemical, although staining, is a very very active chemical species at thwarting ozone / (and oxidation) attacks on rubber compounds.
One nice thing about this chemical is it provides dynamic protection against ozone, while the tire sidewall is deflecting as you are driving down the road. Waxes are also added to the tire sidewall/tread compounds to provide static (unstressed) barrier protection against ozone/oxygen attacks.
If you did not have this in your tire sidewall, you would get little cracks in your sidewall. In fact, ozone attacks rubber so fiercely that older tires (where the PPD and waxes have almost totally evaporated from the compound ) may start to ozone crack. There are some strategies to getting around this though.
Old Apr 19, 2003 | 01:25 AM
don hall's Avatar
don hall
Default Re: Heres your answer: (dizwiz24)
What was the question?
Old Apr 19, 2003 | 02:00 AM
radwebster's Avatar
radwebster
Default Re: Heres your answer: (Oldman)
most likely http://forums.corvetteforum.com/zerothread?id=539941
Old Apr 19, 2003 | 03:12 AM
CanadaVette's Avatar
CanadaVette
I don't know the question but that was one hell of an answer.
Old Apr 19, 2003 | 03:25 PM
pwrful c4's Avatar
pwrful c4
What ever the question was the answer was very technical.Thats a lot of knowledge on the subject. :steering:
Old Apr 19, 2003 | 05:54 PM
GDP's Avatar
GDP
What is this, Jeopardy? :confused:
Old Apr 19, 2003 | 08:31 PM
dizwiz24's Avatar
dizwiz24
Default Re: Heres your answer: (GDP)
Sorry I messed that one up.
This is a response to the brown color that forms on tire sidewalls.
ha ha..that was funny whoever mentioned jeopardy.
The question would be: What causes a tire sidewall to turn brown.
To Heres your answer:
